Configure Employee Experience Settings (part 1)
  • Jul 6, 2025 7:41 PM UTC
  • Oct 4, 2026 8:48 AM UTC
  • 1318 views
This article is the first part of a series of articles to help administrators configure the Employee Experience. You can view part two here.
The Appspace Employee Experience is your organization’s central location for employees to view corporate content that is published to them, and access 3rd party applications utilized within the company. Therefore, it is only natural that organizations would like to customize their Employee Experience to match their organization’s branding, and the ability to enable only the features used within the organization, giving it that personal touch.
These customizations can be done within the Appspace console by an Account Owner, or Location Admin by navigating to the Settings > Configuration > Employee Experience tab from the Appspace menu. Configuration settings that are applied here would affect the Employee Experience, Appspace Mobile App, and also the Visitor Kiosk card.
This article provides Administrators with instructions to configure various Employee Experience settings, including branding, theming, and 3rd-party application links utilized within the organization on the Employee Experience.
What's New
Features released in Appspace 8.8-ac.5 Lynx
  • Improvement to the navigation bar in the Employee Experience allows dynamic adjustment of menu items based on available space and configured maximums in theme settings, with extra items grouped under More, which administrators can configure in the console under Settings > Configuration > Themes > Design.
Brand Settings for Employee Experience
The Brand tab contains settings focused on customizing the organization’s branding for the Employee Experience.Refer to the Configure Brand Center in Appspace Console article for more information on how to configure the brand for your organization.
The Navigation settings listed below contain settings focused on customizing the navigation menu on the Employee Experience.
The Navigation settings can be accessed via the Settings > Configuration > Employee Experience > Navigation tab within the Appspace console.
Configure Navigation Menu
The Navigation menu setting option allows Admins to manage and configure the sections (features) displayed on the Employee Experience navigational menu based on user permissions, or organization branding strategies.
The layout for the Navigation tab organizes the sections in the same order as they would appear within the Employee Experience navigation menu, with each row listing the Section name, Target users, and Language translations available for each section. Here you may perform the following actions:
  • Select Location – Display the sections based on the Location selected.
  • Users – Select the user or user groups from the drop-down to display the sections based on the target audience selected.
  • Preview – Click to preview the sections as displayed in the navigation menu on the Employee Experience.
  • Sort Sections – Click and drag the Sort (⋮⋮) icon up or down to move the sections based on your organization’s priority and branding strategies.
  • Click the Ellipsis (…) at the end of a section to perform the following actions:
    • Edit –  Configure the section.
    • Disable / Enable – Enable or disable the section from being accessed.
    • Move to Top / Bottom – Sort the sections based on your organization’s priority and branding strategies.
To configure the Section within the navigation menu, click the ellipsis of the desired section menu item, and click Edit:
  • Section – Displays the section name, or can be renamed to align with your organization’s branding.
  • Language – Displays the language of the section, with the option to manually translate, or use AI to translate the selected language, or all languages available.
  • Icon – Displays the icon of the section.
  • Target – Displays the target audience of the section, with the option to select “Specific Users, Groups, or Locations” as the target audience of the section. Defaults “All Users” in Appspace.
    • Add Users, Groups, or Locations – Assign the desired users, user groups, or locations as the target audience of the section.
  • Status – Displays the status of the section, with the option to enable or disable the section from being accessed.
Add URL Navigation links to the Navigational Menu
In addition to the default tabs in the Employee Experience navigation menu, the Navigation menu allows administrators to add custom menu items that link to internal or external URLs. These items can be tailored to reflect the organization’s specific branding and themes within the Employee Experience interface.
Follow the instructions below to add a URL link as a menu item to the navigational menu.
  2. Click the ☰ Appspace menu, and click Settings > Configuration.
  3. Click the Employee Experience tab, and click Navigation from the side panel menu.
  4. Click the +Create button in the upper-right corner of the screen. Select URL and click Next.
  5. In the Create URL Navigation window, configure the following fields:
    • Display text – Specify the title that will be displayed for the menu item.
    • URL – Enter the URL that the menu item will open when clicked.
    • Icon – Select an icon for the menu item.
    • Audience – Select the audience that the menu item will be displayed to.
    • Visible in – Select if the link will be visible to the Web, Web mobile, and or Native mobile (app) platforms. You may select more than one option or all options.
    • Status – Set the menu item to be Enabled (visible) or Disabled.
  6. Click Save.
Add and Configure Mega Menu
(New) A Mega Menu is an expandable navigational menu with a larger panel that can display multiple columns with links, headings, media, and interactive elements in an HTML container. Administrators can create and configure Mega Menus in the Employee Experience navigational menu for an organization’s specific branding and themes.
Follow the instructions below to create and configure a Mega menu in the navigational menu.
  4. Click the +Create button in the upper-right corner of the screen. Select Mega Menu and click Next.
  5. The Create Mega Menu Navigation page is displayed. The main section displays a preview of the Mega menu as it is being created.
  6. In the General section, enter the following fields:
    • Display text – Specify the title that will be displayed for the Mega Menu.
    • URL – Enter the full URL for the landing page that users will be directed to when they click on the Mega Menu display text. The URL entered must be in complete format (e.g., https://www.yahoo.com). This field is optional.
    • Icon – Select an icon for the Mega Menu.
    • Audience – Select the audience that the Mega Menu will be displayed to.
    • Visible in – Select if the Mega Menu will be visible to the Web, Web mobile, and or Native mobile (app) platforms. You may select more than one option or all options.
    • Status – Set the Mega Menu to be Enabled (visible) or Disabled.
  7. Click Columns to expand the section.
  8. One column is enabled by default. Click + to create additional columns. You can add up to four columns.
  9. Select the column that you wish to edit. For each column, Click +Add and select one of the following:
    • Link – Displays an internal or external link, similar to the URL Navigation Link in the section above.
    • Icon Block – Displays a link as an icon, accompanied by a title and description.
    • Featured Media – Displays an image link with a title. You can specify the size of the image (on a 1:1 ratio) for both web and mobile versions.
    • HTML Container – Displays a specified URL or a web snippet as a preview block of the web content. You can specify the size of the preview block (on a 1:1 ratio) for both web and mobile versions.
    • Header – Displays a text as a Heading in the column.
  10. Click Save.
Banner Settings for Employee Experience
The Banner settings listed below contain settings focused on customizing the Banner graphics on the Employee Experience.
The Banner settings can be accessed via the Settings > Configuration > Employee Experience > Banner within the Appspace console.
Configure Banner Content Type
The Select Content Type setting option allows Admins to determine the Banner Content displayed on the Employee Experience based on your organization’s branding strategies. The Banner’s recommended size is 300 px x 1170 px.
To configure the Select Content Type setting, select the desired content type from the drop-down menu:
  • None – Disables the banner.
  • Default – Displays the default “Welcome to the Employee Experience” product banner.
  • Media – Displays media content as the banner, by selecting or uploading the content from the Library.
  • Webpage – Displays web content as the banner, by entering the URL in the URL field.
  • Last Content Posted – Displays the last content posted on the Employee Experience as the banner.
  • Features Posts – Displays featured posts as the banner.
Theme Settings for Employee Experience
The Theme settings listed below contain settings focused on customizing the themes for the Employee Experience.
The Theme settings can be accessed via the Settings > Configuration > Employee Experience > Themes within the Appspace console.
Configure Employee Experience Themes
The Themes setting option allows Admins to customize the Employee Experience Home screen layout, tailoring the organization’s branding and user experience to specific locations (campuses or buildings) by adjusting key elements such as column layouts, widgets, logos, and footers.
Add Location-based Themes
Follow the instructions below to configure the Employee Experience theme for a new location.
Themes assigned to a location will also be extended to sub-locations that are not individually themed.
  3. Click the Employee Experience tab, and click Themes from the side panel menu. Click +Create.
  4. Click the Select Location field. From the drop-down menu, select a location, expand a location to select a sub-location, or enter the location name in the Search locations field. Click Create.
  5. The theme of the Employee Experience for the location is created. You can preview the web, mobile, and tablet versions of your theme in the left section.
  6. The Audience section allows you to change the current theme’s location. Expand the section and click the Select location field to search or select another location or sublocation for the theme. You can select only locations that do not have a theme assigned.
  7. For Layout, expand this section to change the column layout and column names.
    • Web Layout – This sets the number of columns displayed in the Employee Experience. You can select your layout to be 1, 2, or 3 columns.
      If you reduce the number of columns in the Employee Experience, you will be asked what to do with the widgets in the removed column:
      • Move widgets – select a remaining column to move the widgets from the removed column.
      • Delete widgets – delete the widgets from the removed column.
    • Column name – Enter the name of each column in the Employee Experience, or leave the field empty to have the default name selected.
    • Language – The language drop-down menu next to each Column name allows you to set the language translation for the Column name.
    • Mark as Primary in Mobile – If there is more than one column, you may select a column as the first displayed in the Appspace App for Mobile. Select the ellipsis to set the column as the primary column in mobile.
  8. For Design, expand this section to customize the colors and logo displayed for the Employee Experience theme:
    • Primary Menu – Configure the maximum number of menus displayed on the navigation bar of the Employee Experience.
      By default, the number of menu items is set to 6 and can be increased to a maximum of 10; however, the display will adjust based on the screen size in the Employee Experience.
    • Theme Colors – Select your desired primary and secondary colors for the theme. Click the Restore to default icon to restore the default colors.
    • Web Logo – Drag and drop or click the icon to upload an image file for the logo on the Employee Experience. The recommended image resolution is 200px x 80px. Click the delete icon to remove an uploaded logo.
    • Web Logo Size – Drag the slider to set the logo size on the Employee Experience.
    • Mobile Logo – Drag and drop or click the icon to upload an image file for the logo on the Employee Experience for Mobile. Click the delete icon to remove an uploaded logo.
    • Mobile Logo Size – Drag the slider to set the logo size on the Employee Experience for Mobile.
  9. For Widgets, refer to the article Configure Widgets for Employee Experience Themes.
  10. Expand the Footer section to create and customize the footer of the Employee Experience. You can use this to display information at the bottom of the page, such as additional links or copyright notices.
    • Click +Create to create a footer.
    • Text and Background Color – Select the color for the footer text and background.
    • Hide in Mobile – Sets the option to not display the footer in the Appspace Mobile App.
    • Columns – Click + to add up to four text columns to the footer. For each column, enter and format the text in the text editor. Click the ellipsis next to each column to delete or move the position of the column.
  11. At the upper-right corner, click Save to save your changes.
Search and Edit Location-based Themes
Follow the instructions below to edit location-based themes:
  4. Click the Locations field. Select a location or sub-location from the drop-down menu or enter the location name in the Search locations field.
  5. Click the ellipsis (…) icon at a location, building, or campus. You can perform the following:
    • Click Preview to view the Employee Experience theme.
    • Click Edit to configure the theme, or Delete to remove the theme for the location.
    • Click Copy and select a new location from the drop-down list to copy the theme to the location.
