Complete List of Device Properties (Part 1)
  • Jul 3, 2025 1:41 PM UTC
  • Sep 29, 2026 6:32 AM UTC
  • 5973 views
Custom device properties are used to configure devices for specific behaviors for any Appspace supported device in the Appspace console. This article lists the device properties available, including their functions, default values, and value range (where applicable), as well as the supported devices.
Note:
See Complete List of Device Properties (Part 2) for additional properties.
Appspace App Device Properties
A list of device properties used in all Appspace App supported devices.
Alert Card
Click for instructions to create an Alert card.
Direction to building exit point
  • Property: card.alert.exitdirection
  • Default Value: –
  • Value Range: right / left / down / up / upright / downright / upleft / downleft / elevatorup / elevatordown / escalatorup / escalatordown / stairsup / stairsdown
  • Value Format: Alphanumeric
  • Supported Device: All Appspace App based devices
  • Availability: Appspace App
Only one device property value can be supported at one time. If there are no device properties, the bottom banner with the direction on the card will be disabled.
Android Device Properties
For Android device installation and configuration information, refer to Install Appspace App and Configure Android Devices.
Enable in-app browser
  • Property: player.media.webengine
  • Default Value: inappbrowser
  • Supported Device: All Appspace App Android based devices in device mode. Not applicable to Android TVs.
  • Availability: Appspace App 2.19.2
For information on using this property and the associated limitations please refer to: Enable In-App-Browser for Android
Chrome IWA Device Properties
Configure Printer for Chrome IWA
  • Configure a printer for Chrome IWA devices on ChromeOS using the device.printer.options device property. Specify the printer by name or by an IPP/IPPS address.
    • Property: device.printer.options
    • Default Value: –
    • Value Example: {"printer": "ipp://192.168.11.12:631"}
    • Value Format: JSON
    • Supported Device: Chrome IWA on ChromeOS
    • Availability: Appspace App 2.100.0
BrightSign Device Properties
For BrightSign device installation and configuration information, refer to Install Appspace App on BrightSign.
Enable UDP on BrightSign devices
  • Property: remote.BrightSign.forceudp
  • Default Value: –
  • Value Range: true or false
  • Value Format: Boolean
  • Supported Device: BrightSign
  • Availability: Appspace 7.0.x
Closed caption or subtitles for video
  • Property: custom.media.video.cc
  • Default Value: –
  • Availability: Appspace 6.0.x
Closed caption or subtitles for Live Channels
Requires the custom.media.video.cc device property above to work.
  • Property: custom.media.video.cc.BrightSign
  • Value: pid=2, type=C608;;
  • Availability: Appspace 8.x
Closed captioning is now supported on Live channels when the following Channel selection mode is selected for device playback:
  • Autoplay published channels
  • Administrators can select a single channel
Enable video stretching when in interactive (channel browsing) mode
  • Property: player.play.video.aspectratio
  • Default Value: uniform
  • Value Range:
    • stretch – video may appear stretched.
    • uniform – video may appear scaled to fit the window.
    • uniform fill – video may appear cropped.
  • Supported Devices: BrightSign
  • The aspect ratio property update takes effect after the current video ends in a playlist channel.
  • As live channels do not have an end, the update takes effect after the user exits and reselects the live channel again.
  • In an advanced channel (sign), by default, the video will be stretched to fill the window.
Output audio in both HDMI and analog output
Configure AC3 compressed audio passthrough on BrightSign devices. Use player.brightsign.forceac3 to enable AC3 passthrough and player.brightsign.compaudio to specify the compressed audio output route.
  • Property: player.brightsign.forceac3
  • Default Value: –
  • Supported Device: BrightSign devices
  • Property: player.brightsign.compaudio
  • Default Value: –
  • Value Range: hdmi;analog
  • Value Format: String
Video overlay in advanced channel Media Zone widget
  • Property: custom.media.video.layerindex
  • Default Value: –
  • Value Range:
    • -1: Places the video behind all graphics.
    • 0: Disables “hwz” mode completely. Widget overlays on top of the video.
    • 1: Places the video in front of all graphics (the default setting). Video is shown, but other widgets will be hidden.
    • 2: Places the video in front of all graphics, as well as a second video element. The first video is shown, but the second video and other widgets will be hidden.
When “hwz” is enabled, the video is rendered as a video element, ensuring the highest possible frame rate and video quality. When “hwz” is disabled, the video is rendered as a graphics element.
iOS Device Properties
Enable Kiosk Mode
  • Property: player.ios.asam.enabled
  • Default Value: –
  • Supported Device: iOS Devices
  • Availability: Appspace App 2.26
Enable Kiosk Mode Option in Device Menu
  • Property: player.ios.asam.allowed
  • Default Value: –
Improve Device Menu Touch Pattern Sequence
Overrides the current touch pattern sequence used to access the Device Menu when in kiosk mode
  • Property: player.devicemenu.invokepattern
  • Default Value: –
  • Value Range: top-left or top-right or bottom-left or bottom-right
Enables Hotspot Areas to Appear as the Top Layer
Allows the next hot spot of the touch pattern sequence to appear as the top layer when the touch pattern sequence is initiated. This is particularly useful when cards or web content is displayed.
  • Property: player.devicemenu.hotarea.enable
  • Default Value: –
Customize Hotspot Area CSS Stylings
  • Property: player.devicemenu.hotarea.style
  • Default Value: –
  • Value Range: background:<value> or border:<value>
  • Value Example: player.devicemenu.hotarea.style = border: 2px solid red; background: white
Samsung Tizen Device Properties
  • Supported Device: All Appspace App Samsung Tizen based devices in device mode.
  • Availability: Appspace App 2.22.3
Channel Browsing Display Settings
For information about channel browsing or interactive mode, refer to Getting Started with Channel Browsing. For more device properties specific to channel browsing, refer to Customize Appspace App 2.0 Channel Browsing.
Change channel title text color
  • Property: player.play.themesettings.home.channel.title.color
  • Default Value: –
  • Value Range: RGB Hex code (#FFFFFF), or RGBA (255,0,0,0.5)
  • Supported Devices: All Appspace App based devices
Change channel group title text color
  • Property: player.play.themesettings.home.channelgroup.title.color
  • Default Value: –
Change channel background color
  • Property: player.play.themesettings.home.background.color
  • Default Value: –
Download content locally
  • Property: play.cache
  • Default Value: –
  • Value Range: videos or all
  • Value Format:
Enable persistent back button for channels in full screen
  • Property: player.play.themesettings.channel.fullscreen.back
  • Default Value: false
  • Value Range: Boolean
Set placement of persistant back button for channels in full screen
  • Property: player.play.themesettings.channel.fullscreen.back.placement
  • Value Range:
    • topleft
    • topright
    • bottomright
    • bottomleft
Hide channel group title on Home, Recently Added, and Channel Group screens
  • Property: player.play.themesettings.home.channelgroup.title.enable
  • Default Value: true
Hide Cursor
  • Property: player.cursor.visibility
  • Default Value: hidden / auto / visible
  • Value Range: String
Hide Search icon
  • Property: player.play.themesettings.home.search.enable
Hide Sidebar
  • Property: player.play.themesettings.home.sidebar.enable
Customize sidebar text color
  • Property: player.play.themesettings.home.sidebar.color
  • Default Value: –
Customize sidebar background color
  • Property: player.play.themesettings.home.sidebar.backgroundcolor
  • Default Value: –
Customize sidebar highlight and accent color
  • Property: player.play.themesettings.colors.accent
  • Default Value: –
Enable background scroll
  • Property: player.play.themesettings.home.background.scroll
  • Default Value: –
  • Value Range: scroll, blur, or none
Customize background scroll behaviour
  • Property: player.play.themesettings.home.background.behavior
  • Property: player.play.themesettings.home.logo.enable
Enable Clock
  • Property: player.play.themesettings.home.clock.enable
Customize Clock color
  • Property: player.play.themesettings.home.clock.color
  • Default Value: –
Customize Clock format
  • Property: player.play.themesettings.home.clock.format
  • Default Value: –
  • Value Format: HH:mmA (clock will display as 14:29PM)
Input Example Description
H HH 0..23 Hours (24 hour time)
h hh 1..12 Hours (12 hour time used with a A.)
k kk 1..24 Hours (24 hour time from 1 to 24)
a A am pm Post or ante meridiem (Note the one character a p are also considered valid)
m mm 0..59 Minutes
s ss 0..59 Seconds
S SS SSS 0..999 Fractional seconds
Z ZZ +12:00 Offset from UTC as +-HH:mm, +-HHmm, or Z
Set content to play entire playlist once, before returning to main menu
  • Property: player.play.themesettings.playlist.endofplaylistbehaviour
  • Default Value: –
  • Value Range: “goback”
  • Availability: Appspace App 1.24
Play single/default content during idle time – Behaviour
For idle behaviour to work correctly, both the player.play.idle.behaviour and player.play.idle.duration device properties must be added to the device.
Property: player.play.idle.behaviour
  • Default Value: –
  • Value Format:
    • lastused
    • live=<channel_number>
    • sign=<sign_ID>
    • channel=/<Channel Group Name>/<Channel Name>
    • channel=/Channels/<Channel Name>
    • channel=Live Channels/<Live Channel Name>
  • Availability: Appspace App 1.31
channel= is /<Channel Group name>/<Channel name>.
  • channel=/Channels/<Channel Name> finds a channel only when it is in a group named Channels. It does not target a Live Channel.
  • For a Live Channel, use channel=/Live Channels/<Live Channel Name>.
  • You can also target a Live Channel by number with live=<channel number>.
Play single/default content during idle time – Duration
  • Property: player.play.idle.duration
  • Default Value: –
  • Value Format: <idle timeout in seconds>
Display the recent Channels or Content on the Home screen
  • Property: player.play.themesettings.home.channelgroup.summary
  • Default Value: –
  • Value Range:
    • channel
    • content
Sort live channels in the Home and Channel Group screens
  • Property: player.play.themesettings.home.livechannels.sortby
  • Default Value: name
  • Value Range:
    • name
    • number
    • code
Enable Recently Added channels
  • Property: Player.play.themesettings.home.recent.enable
  • Default Value: True
Configure channel rows
  • Property: player.play.themesettings.home.channelrows.count
  • Default Value: –
  • Value Range: any number (integer)
Configure channel columns
  • Property: player.play.themesettings.home.channelcolumns.count
  • Default Value: –
Configure on-screen engagement
  • Property: player.social.qrcode.enable
Device Publishing
Display Exclusive Playlist Chanel
  • Property: player.play.exclusive.channel
  • Default Value: <Playlist Channel ID> or <Playlist Channel Name>
  • Supported Device: All Appspace App 2.x based devices
  • Availability: Appspace 8.0.x
Device Display Settings
App display rotation on the player
  • Property: display.rotation
  • Default Value: –
  • Value Range: -90, 0, 90, 180, 270 (degrees)
BrightSign devices do not support the automatic orientation setting, hence require the device property to be set to portrait or landscape. For more information, visit the Configure device rotation settings section.
App display automatically reloads to fit the size or orientation
  • Property: display.responsive
Reload App display on resize
  • Property: display.onresize.reload
The App/card display is resized (smaller) when an on-screen keyboard is launched, resulting in the card being reloaded continuously. Set this property to “false” to prevent the card reload, and to ensure the on-screen keyboard is functional.
Room Schedule and Schedule Board Cards
Note:
For information on Room Schedule card, refer to Single-Room Scheduling.
Improved “You Are Here” Wayfinding for Maps
Devices with a floor plan location configured in Devices > Map can now provide their mapped location to supported cards, including the Schedule Board card. This enables the Schedule Board card to use the device's precise map location as the “You Are Here” starting point for wayfinding.
  • Property: device.location.mapnode
  • Description: Stores the device’s configured floor plan location and map coordinates for use by supported cards, including the Schedule Board card.
  • Behavior: Automatically updates when the device’s mapped location changes.
  • Visibility: Not displayed on the Device Properties page and cannot be manually added or edited.
  • Property: card.schedule.map.locationid
  • Default Value: <POI ID>
  • Value Range: –
Use the following device property to configure the wayfinding starting point using Point Of Interest coordinates.
  • Default Value: “coordinates”:[###,###],”floorNumber”:#
  • Value Range: –
  • Value Format: Numeric
Note: For instructions on configuring the mapped device location, see Create and Configure Devices Map View. For information on configuring Points of Interest and their coordinates, see the Configure Floor Plan section in Maps Service - Configuring Locations, Floor Plans, and Layers.
Display meeting room capacity
  • Property: card.room.capacity
  • Default Value: –
  • Value Range: –
The Room Schedule card will display the room capacity from 1 to 100, anything more than 100 would be displayed as >100.
Display meeting room facilities
  • Property: card.room.facilities
  • Default Value: –
  • Value Range:
    • Ethernet
    • Phone
    • Projector
    • VideoConference
    • Whiteboard
    • Wifi
    • Screen Share
  • Value Format: <facility 1>,<facility 2>, <facility 3>
Display meeting room label
  • Property: card.room.label.room
  • Default Value: –
Display meeting room Resource ID
  • Property: card.room.roomid
  • Default Value: –
  • Value Range: –
  • Value Format:
    • resource e-mail <address@outlook.com> : If Microsoft Outlook Calendar is used.
    • resource id <numeric id> : If Google Calendar is used.
Display meeting room name
  • Property: card.room.roomname
  • Default Value: –
  • Value Range: –
Display meeting room notes
  • Property: card.roon.roomnotes
  • Default Value: –
  • Value Range: –
Video Wall/Synchronized Playback
Read the introduction to Appspace and Video Walls, or the Setup Synchronized Playback Displays on Multiple Screens, and Setup Video Wall Displays configuration articles for more information.
Assign tile ID in numeric to device, to form a video wall
  • Property: player.videowall.tileid
  • Default Value: –
  • Supported Devices: All Appspace App-based devices supporting synchronized playback/video walls
  • Availability: Appspace App 1.50
Numbering is done left to right, and top to bottom.
Define pre-load time in seconds for content
  • Property: player.content.preloadtime
  • Default Value: –
  • Unit: sec
  • Value Format: <x seconds>
  • Supported Device: All Appspace App-based devices supporting synchronized playback/video walls
This will help to adjust content playback on devices that take a longer time to load and play, i.e. low powered devices, so it will play in a synchronized manner.
Recommended preload time:
LG WebOS: 3.5 seconds, Chrome: 1.5 seconds, UWP: at least 2 seconds
Enable/disable overlay on debug information screen
  • Property: player.clocksync.debug
  • Default Value: –
Enable synchronized playback at layout level
  • Property: player.scheduling.mode
  • Default Value: –
  • Value Format: synchronized
Set controller device IP used by worker device to synchronize clock
  • Property: player.clocksync.controller.ip
  • Default Value: –
  • Value Format: IP address <xxx.xxx.xxx.xxx>
Set device as a controller or worker
  • Property: player.clocksync.mode
  • Default Value: –
  • Value Format: controller or worker
Split canvas into grid of tiles to match number of displays
  • Property: player.videowall.tilematrix
  • Default Value: –
  • Value Format: x,y (x is horizontal number of screens, y is vertical number of screens)
