Manage Workspace, Desk, or Room Reservations - Concierge
  • July 4, 2025
  • October 4, 2026 at 7:55 AM
  • 989 views
This article provides instructions for employees with Concierge permissions to manage workspace reservations, such as office spaces, meeting rooms, and hot desks via the Concierge dashboard in the Appspace Employee View.
The dashboard will provide the Concierge user with a calendar view of reservations within the location that they have visibility over, with the following criteria:
  • View current, historic, and future reservations with a calendar view.
  • View the calendar in a daily, weekly, or list format.
  • The calendar view will display reservations based on selected workspace resources from locations that are specific to or assigned to the concierge.
  • Reservation details can be expanded to display additional information pertaining to the reservations, such as organizer, attendees, duration, meeting name, and other reservation details that are not displayed on the calendar view.
  • Reservations can be filtered according to workspace resource type, and status.
  • (New) View canceled and deleted reservations by selecting the relevant statuses from the status filter (this is not shown in the default view).
  • Reservations can be exported to a .xlsx format, containing all reservation records made.
  • (New) Besides viewing reservations, concierge users can also be provided permission to create, edit, cancel, override (book rooms that are already reserved, e.g. for urgent or high-priority use) and approve reservations.
  • (New) Besides viewing checkpoints in reservations, the concierge user can be provided permission to add, edit and cancel and complete checkpoints in reservations.
The Calendar view will NOT allow the Concierge user to select Users and view their personal Calendars, but will have the ability to see the users associated with a reservation at one of the resource for which the Concierge user has visibility
What's New
Features release in Appspace 8.2 Andromeda
  • The Concierge List View provides a comprehensive overview of reservations.
  • Reservation Services, allows the concierge to Download Checkpoint Information.
The Employee View is only available on Appspace public/private cloud 8.0 and later. It is not supported on 8.0 on-prem.
Employee View
The Concierge dashboard provides employees assigned with Concierge permissions a calendar view of all reservations under their purview, in addition to the existing method of viewing historic and future reservations in a list view. Employees with concierge permissions are also able to view and manage the reservations of workspaces in locations they have been assigned to.
The Concierge dashboard now has a Save button allowing the Concierge user to save the selected filtered calendar view, which can then be accessed by the Concierge user upon subsequent login/access to the dashboard.
(New) The Reservations Calendar widget provides an additional way for Concierge users to view and manage reservations across multiple workspaces from the Employee View, Spaces, Communities, or Topics where the widget has been added. The Reservations Calendar widget is separate from the Concierge dashboard calendar described in this article. For instructions, see Use the Reservations Calendar Widget.
Configure Concierge Dashboard View
Follow the instructions below to configure your Concierge dashboard in the Employee View:
  1. Log in to your Employee View with your Appspace Premium User credentials that have been assigned with Concierge permissions.
  2. Click More from the top menu, and click Concierge.
  3. Ensure that the Reservations tab is selected.
  4. The calendar will display the current date by default. If you wish to view or manage reservations on another date, click the desired date on the Mini Calendar.
  5. Proceed to enter the name of the workspaces you wish to view on the calendar in the Workspaces input box.
  6. Alternatively, you may select the Location of the workspaces you wish displayed from the drop-down menu, which will then populate the calendar with the six latest workspaces available.
    • If the workspace you wish to view was not added automatically, you may manually add the name of the workspace in the Workspaces input box.
    • If you wish to remove a workspace from being displayed, click the “X” beside the workspace name tag from the Workspaces input box to remove it.
  7. Once done, the concierge calendar will display all reservations within its workspace column according to the time and date on the calendar.
    Reservations set to private will appear as “Workplace Reservation” instead of showing the full name. However, the full name will be visible to the host, meeting attendees, and the location administrator.
  8. Optionally, the following filters may be used to further narrow down the reservations you wish to display:
    • Resource Type – Display reservations based on the workspace type.
      • Room
      • Spaces
      • Points of Interests
      • Connected Resources
    • Status – Display reservations based on the reservation status. You can select multiple statuses simultaneously.
      • Edit and Cancel actions are not available for deleted reservations, and checkpoints can be viewed but cannot be modified.
      • Reservations canceled by a user or through a calendar provider are kept indefinitely. Deleted reservations are kept for the duration configured in retention settings. To configure how long deleted reservation data is retained, refer to the Configure Reservation Settings article.
      • Comments are visible in the reservation panel for all reservation statuses, including Canceled and Deleted. Users can add, edit, or delete their own comments.
      • Active
      • Check-in
      • Confirmed
      • Has conflicts
      • Not confirmed
      • Completed
      • (New) Canceled
      • (New) Deleted
  9. Click the Save button to save the Concierge dashboard with the current calendar view and its selected filters. When you log in to the Employee View again, you will be presented with the same filtered calendar view.
    Once this calendar view is saved, when you log out and log back in again to your Employee View, workspaces that you have added here will be displayed in the same order.
Create Workspace Reservations
Follow the instructions below to create a reservation from your Concierge dashboard in the Employee View:
  1. In the Employee View, click More from the top menu, and click Concierge. Ensure that the Reservations tab is selected.
  2. Reserve a workspace by following the instructions in this article.
View and Manage Workspace Reservations
Follow the instructions below to manage a reservation from your Concierge dashboard in the Employee View:
  2. Select the appropriate filters if desired to view the relevant reservations.
  3. (New) You can view the following information on a reservation if available:
    • Order summary – An icon indicating a request will be displayed when a reservation is linked to a business or catering service. Click the icon to display the order summary for the reservation.
    • Checkpoints – Move your mouse over the checkpoint icons to display checkpoints (including service forms or menus) tied to the reservation.
  4. Click the desired reservation to manage.
    (New) If Reservation Labels are enabled, you can assign or change a label for the reservation. Reservation Labels are configured by administrators under Reservations > Settings > Labels. For configuration instructions, see Configure Reservation Labels.
  5. View, add and manage comments to the reservation - You can add comments to a reservation to share updates or additional information, and edit your own comments without needing to click Edit for the reservation. You can also view comments if they have been posted by other users.
    • After selecting the reservation to manage, scroll to the bottom of the reservation pane.
    • If the reservation does not have any comments yet, click Add a comment to write and post a new comment.
    • (New) You can format the text your comments using the formatting toolbar. Select the text and select to apply one of the following formatting options: Bold, Italic, Link, Bulleted list or Numbered list.
    • Click View All Comments to see all existing comments on the reservation. From here, you can also edit your own comments as needed.
    • (New) Each comment is displayed with a timestamp indicating the date and time it was posted. The year is not shown for comments made in the current year.
  6. To edit the workspace reservation, click the Edit icon or View More link, and proceed to make the following edits to the workspace reservation.
    • Change the Reservation Name.
    • Change the Date, Time, or Duration of the workspace reservation.
    • Enable or disable Recurring Reservations (by clicking More Options).
    • (New) Change the Organizer – Concierge users with the appropriate permissions can reassign the organizer of an existing reservation. Ownership, permissions, and notifications are transferred to the new organizer while preserving reservation details, services, comments, and reservation history. An audit record is maintained for organizer changes.
    • Add or remove Attendees and Visitors.
      Reservations set to private will display the event’s host name but keep the attendee list hidden. However, the host, meeting attendees, and the location administrator will still have access to the full list of attendees and visitors.
    • Edit the workspace reservation Notes.
    • Enable or disable the Reservation privacy of the workspace reservation.
  7. Click CONFIRM.
View Orders for Services in Reservations
The Orders tab displays a comprehensive list of all incoming orders for catering orders and business requests. This allows the concierge to have an overview of the tasks required for the selected day’s reservations and to prioritize their work accordingly.
Follow the instructions below to view orders (including cancelled orders) for Business or Catering services in checkpoints for reservations:
  2. Click More from the menu, and click Concierge.
  3. Select the Orders tab.
  4. The calendar displays the current date by default. To view a different month, click the arrows next to the month name, then select a date from the calendar.
  5. You can filter the results by Location, Order types, and Order Status. or leave them to select all locations and order types.
    • Location - select the location from the drop-down list.
    • Order types - you can select to view All orders, or only Catering or Service orders.
    • (New) Order status - select to view All Statuses, or one of the following:
      • All Statuses
      • Confirmed orders
      • Canceled orders
      • Completed orders
    • (New) Workflow - select to view one or more of the following workflow states, or leave as blank to select all:
      • Catering - Pending, In Progress, Complete, Cancelled.
      • Business - Pending, Complete, Cancelled.
    • (New) Asignees - select one or more of the concierge users the orders were assigned to.
  6. The orders for reservations on the selected date are displayed.
  7. Select an order from the list to view the Order summary for the reservation.
Add Services to a Reservation
(New) Concierge users with the Add permission for Checkpoints Permissions can submit additional service requests (such as catering, AV equipment, or room setup changes) to reservations even after initial service requests have been made or canceled. After the service is added, the change is automatically routed to the appropriate service provider, helping to ensure that updated the service requirements are fulfilled.
Follow the instructions below to add Business or Catering services to a reservation:
  • Concierge users must have the Add permission for Checkpoints Permissions.
  • The Add Services option is only available for reservations with the following criteria: ​​​​
    • The resource has a Business or Catering service checkpoint configured.
    • The reservation is not in the Completed, Canceled, or Conflicted status.
    • The concierge user has completed a service order checkpoint or canceled the service order within the reservation.
  2. Click More from the menu, and click Concierge. Ensure that the Reservations tab is selected.
  3. Click the desired reservation to manage. Refer to the Note above for the criteria for reservations to have this option.
  4. Select the Add Services option. A service form will appear, displaying available services. The concierge can then select which business or catering services are needed. Perform the steps in the Complete Service Checkpoint in a Reservation article.
  5. Additional service orders added to the reservation will also appear in the following reports. Refer to the Download Checkpoint or Service Information from Concierge section below.
    • Reservation Services 2.0 report
    • Order summary report
    • Concierge menu/form report
    • Concierge report (downloadable from calendar)
Approve a Reservation
  • (New) Concierge users must be provided Approve permissions under Reservation Permissions to be able to approve a resource. Refer to Concierge Settings for Reservations.
  • An approval workflow must first be created for a resource. See the Create Approval Workflow section under Configure and Manage Workspace & Desk Reservations - Resource Rules.
(New) Concierge users with Approve permissions are able to participate in approval workflows for resource reservations (such as rooms or workplaces). This is especially useful when a particular resource is restricted to special occasions, such as boardrooms.
When a meeting organizer creates a reservation for a resource that requires approval, the assigned concierge user will see the reservation listed in their approval queue. The organizer is also able to view that their reservation is in Pending Approval status in the Reservations tab. Invitees will not see pending reservations or receive any notifications until the reservation is approved.
Follow the instructions below to view the concierge approval queue and approve a reservation for a resource that requires approval.
  3. Under the Concierge section, click the Approvals tab. The approval list will display all reservations within the selected Location according to the date on the calendar.
  4. The calendar will display the current date by default. If you wish to view reservations on another date, click the desired date on the Mini Calendar.
  5. For Location, select the location, campus or building to filter the approval list.
  6. Click the Resource field to select resources from the drop-down list. You can select multiple resources.
  7. Optionally, the following fields may be used to further narrow down the reservations you wish to display:
    • Resource – Click the Resource field and select resources from the drop-down list. You can select multiple resources.
    • Organizer – Enter the name of the organizer and click to select the result. You can enter multiple organizers.
  8. Select a pending reservation in the list to display the the pending reservation details.
  9. Review the reservation details. If you are also assigned Edit permissions under Reservation Permissions, you are also able to click the Edit (pencil) icon to edit the fields in the reservation.
  10. Click Approve to approve the reservation or click Decline.
The reservation will be removed from the list of Approvals. The meeting organizer will be notified (through email) that the reservation was Approved or Declined, and can also view the change in the status of their reservations in the Reservations tab of the Employee View.
Follow the instructions below to download Checkpoint information from your Concierge dashboard in the Employee View:
  3. The calendar will display the current date by default. If you wish to view or manage reservations on another date, click the desired date on the Mini Calendar.
  4. Proceed to enter the name of the workspaces you wish to view on the calendar in the Workspaces input box.
  5. Select the Statuses that you wish to include in the download, similar to the options shown in the Configure Concierge Dashboard View section above.
    (New) The download includes Canceled and Deleted reservations when those statuses are selected in the filter. Status is labeled accordingly in the Status column of the exported file.
  6. (New) For Search by, select either Checkpoint or Services.
    • For Checkpoint, select the desired Checkpoint name from the drop-down menu, or you may search for it by entering the name.
    • For Services, select the desired Service name from the drop-down menu, or you may search for it by entering the name. Do the same for Menus/Forms.
  7. Once done, click the ellipsis of the checkpoint, and click Download.
  8. The spreadsheet (in .xlsx format) will be downloaded to your default folder.
    • (New) For Service reports, refer to Reservation Services 2.0 under this Glossary for the information in the report columns.
  9. Alternatively, you may also click the Advance Filters to filter the checkpoint information based on the following:
    • Response – Select one of the following checkpoint status.
      • Pass
      • Fail
      • Pending
    • Operator – Select an operator for the label or checkpoint options.
      • Contains
      • Does not contain
    • Labels – Enter the checkpoint option you wish to filter.
Appspace Mobile App
Follow the instructions below to configure your Concierge dashboard in the Employee View on mobile devices:
  1. Log in to Appspace with your Appspace Premium User credentials that have been assigned with Concierge permissions.
  2. Click More from the menu, and select Concierge. The calendar will display the current date by default.
  3. Click + Add workspace button. If you wish to view or manage reservations on another date, click the desired date on the Mini Calendar.
  5. Alternatively, you may select the Location of the workspaces you wish displayed from the drop-down menu, which will then populate the calendar with the six latest workspaces available.
  6. Once done, the concierge calendar will display all reservations within its workspace column according to the time and date on the calendar.
  7. Optionally, the following filters may be used to further narrow down the reservations you wish to display:
  8. Once done, click Save.
Follow the instructions below to manage a reservation from your Concierge dashboard in the Employee View on mobile devices:
  1. Launch the Appspace Employee View.
  3. Once you have configured your concierge dashboard view, select and click the desired reservation to manage.
  4. To edit the workspace reservation, click the Edit icon or View More link, and proceed to make the following edits to the workspace reservation.
    • Enable or disable Recurring Reservations.
      The Recurring Reservations checkbox may be disabled due to a limitation where once an event is created, it cannot be changed to recurring. We are currently working on a fix for this.
    • (New) Change the Organizer.
      After the organizer is changed, ownership, permissions, and notification responsibilities are transferred to the new organizer, and an audit record of the organizer change is maintained.
  5. Click CONFIRM.
