Publish Content to Webex for Team Communications
  • July 4, 2025
  • 239 views
Appspace 8’s native integration with the Webex enterprise messaging app allows companies to publish content (messaging, videos, charts) via a Playlist Channel, directly to a Webex chat space.
This integration is ideal for unified team communications and engaging remote workers and keeping the team informed, engaged, and up-to-date, regardless of where they are located globally.
There are several content publishing and viewing options available. Publishers may configure the publishing settings, allowing employees to view the posted content in the chat windowclick on a referral link in the post, or view the content on the Appspace Employee Experience portal (public/private cloud only) via a link in the post.
Read more about the integration architecture and how it all connects here in the Appspace Integration with Enterprise Messaging Apps.
This article provides instructions to configure Appspace for integration with Webex.
  • An Appspace Platform user license for access to the Appspace console.
  • An Appspace Premium user license to view content via the Appspace Employee Experience.
  • Appspace Account Owner permissions to authenticate the enterprise messaging app.
  • Appspace Publisher permissions to publish playlist channels to Webex.
  • Access to a Webex account, with the necessary permission to add the Appspace App bot to Webex chat rooms.
  • Appspace playlist channel(s).  Only a playlist channel is supported for this integration.
Additional Prerequisites for Appspace On-Prem:
  • An Appspace 8.0 on-prem server with an active internet connection and Cloud Integration enabled in the console.
Security and Scope
  • We never store your login informationDuring the account authentication process, you will be asked to enter your credentials for your Webex account. However, Appspace will not store those credentials. Instead, Appspace will receive an API token, which it will use for future communications.
  • We request granular access to your organizationAppspace does not request broad permissions to your organization. The integration only has the permissions required to perform its operation, which is to post content from the Appspace console into the Webex spaces/channels/chats.
  • One way communication protects the privacy of your dataAppspace is unable to see any messages in a channel/space/chat that are not directed to it, and can only see the messages shared via Appspace.
Configure Appspace-Webex Integration
Authenticate Webex Account
Appspace recommends to use a service account with access to all private channels/chat rooms in this app, to create this authentication service for the Appspace bot. This will ensure Appspace is able to publish content to any newly created channels/chat rooms.
Follow the instructions below to configure and link Appspace to the Webex enterprise messaging app.
Appspace Account Owner permissions are required.
  1. Click the ☰ Appspace menu, and select Integration.
  2. Select the Passports tab and click the +ADD button.
  3. In the Select an App to Create a New Passport window, click Webex. You may click the Publishing tag to filter results.
  4. In the Account Settings tab, click the CONNECT ACCOUNT button to authenticate Appspace to Webex. You may need to sign in with your Webex credentials if you’re currently not signed in.
  5. Click the Allow button in the Webex permissions window to grant Appspace integration permissions.
  6. Once complete, you’ll be returned to the Account Settings tab.
  7. In the Account Settings tab, you can perform the following actions;
    • Change the name of the Webex integration, by entering a different name in the Name field.
    • View the Account ID of the Webex integration.
    • View the App Permissions granted to Webex.
    • View and refresh the Status of the Webex integration.
    • Remove the Webex integration, by clicking the Remove Account button. Refer to the Remove Appspace-Webex Integration section below.
  8. In the Permissions tab, you may grant any user or user group the permissions to view or manage this integration.
    • Enter and select the users or user groups from the drop-down list, and select the permissions to grant from the Select permissions drop-down menu.
    • You may also view and remove the users or user groups that have already been granted permissions.
  9. Proceed to the Configure Channel Publishing Settings for Webex section below.
Follow the instructions below to configure the publishing settings for Webex.
Publishing to Apps is only available for playlist channels. Appspace Account Owner or Publisher permissions are required.
  1. Click the ☰ Appspace menu, and select Channels.
  2. Select the desired playlist channel you wish to publish.
  3. Select the Publish tab, and click the Apps sub-tab.
  4. Click the PUBLISH TO AN APP button.
  5. In the Select App window, select the Webex app integration created above, and the chat room to publish the content to from the Select a chat drop-down menu.
  6. Click Show Settings to view additional publishing settings.
  7. In the Post Format section, configure the following:
    • Configure which elements from an Appspace content are included in published posts:
      • Title
      • Article
      • Channel – Displays the Channel Name in the post
      • Thumbnail
        All four display elements are selected by default, however at least one display element must be selected from the drop-down menu.
    • Configure if the content article or caption should be displayed in published posts:
      • Caption Only (Default)
      • Full Article
    • Configure what happens when a viewer clicks the title of the published post:
      • Cloud
        • Do nothing – User reads posted content in the chat window. No other action available.
        • Open in Appspace (Default) – Redirects user to the Employee Experience portal to view the post content in detail.
        • Open Content Referral Link – Redirects user to the referral link set in the content.
        • Open Content Referral Link, fallback to Appspace – Redirects user to the referral link set in the content, or the Employee Experience Portal.
      • On-Prem
        • Open Content Referral Link (Default) – Redirects user to the Referral Link set in the content during content creation.
  8. In the Content Rules section, configure the following:
    • If you would like to Schedule content, select the time zone as this will be used for scheduling, allowing content to be published to the chat room at a predetermined time, according to the scheduling rules set in the playlist channel.
    • If you would like to Restrict content by type, configure the content type you wish to restrict in the published post, select one of the following content types:
      • Images
      • Videos
      • Cards
    • If you would like to Restrict content using tags, enter the content tags of the content that is allowed to be published to the chat room. Content not containing the listed content tags, will not be published in the post.
    • If you would like to Exclude content using tags, enter the content tags of the content that is not allowed to be published to the chat room. Content containing the listed content tags, will not be published in the post.
  9. In the Updating Content section, select what happens when the posted content is updated (after the post was initially published) in the Appspace console:
    • Update post (Default) – Updated content is republished to the existing post in the chat room.
    • Do nothing – Content is not updated in the post.
  10. In the Removing Content section, select the action to perform:
    • Select what happens when content is removed from a playlist channel:
      • Remove Posts (Default) – Remove the post and content published in the chat room.
      • Keep Posts – Do nothing, and keep the post and content published in the chat room.
    • Select what happens when a playlist channel is unpublished from Webex:
      • Remove Posts (Default) –  Remove the published post from the chat room.
      • Keep Posts – Do nothing, and keep the published post in the chat room.
  11. Click SAVE.
Access Channel Publishing Settings for Webex
  2. Select the playlist channel that is publishing to the Webex chat room.
  4. Click CONFIGURE on the selected Webex app integration.
Post Content to Webex Chat Room
Appspace Account Owner, Publisher, or Editor permissions are required.
Post New Content
Follow the instructions below to add new content to the configured channel and post it automatically to the Webex chat room.
  1. Click the ☰ Appspace menu and select Channels.
  2.  Select the playlist channel configured with the above publishing settings.
  3. In the Edit tab, click +ADD, and select, create, or upload content to the playlist channel.
  4. The content will be automatically published to the Webex chat room.
Post Existing Content
Follow the instructions below to publish content already added to the configured channel but not posted to the Webex chat room.
  3. In the Edit tab, select the desired content to publish, and click the enterprise messaging app icon.
  4. Click Post to All Apps.
  5. The content will be automatically published to the Webex chat room.
Repost Content
Follow the instructions below to republish content that was previously posted to the Webex chat room.
  4. Click Repost to all apps.
View Content History
Follow the instructions below to view content history previously posted to the enterprise messaging app chat rooms.
  2. Select the playlist channel that is publishing to Apps.
  4. Click History to view all content previously posted to the enterprise messaging app chat rooms.
View Content in Webex Channel
In the Webex chat room, the Appspace publishing bot will publish content depending on the publishing Post Format settings configured earlier by the administrator in the Configure Channel Publishing Settings for Webex section above.
Link to Employee Experience
If the Post Format settings were configured to “Open in Appspace“, the viewer/user will be redirected to the Employee Experience, when the post title or thumbnail is clicked in the Webex chat room window.
Viewers must have an Appspace user account to login and view the content published to them on the Employee Experience portal. For first-time visitors to Appspace, using SSO with Just-In-Time turned on will provision them into the Appspace console with basic access. Once the user validates with their IdP, they will have access to published content via the portal.
Read Post in Webex Chat Room
If the Post Format settings were configured to display “Full Article” and “Do nothing“, the viewer/user will be able to read the entire contents of the post in the Webex chat room window, when the post title or thumbnail is clicked in the Webex chat room window.
View Referral Link in Web Browser
If the Post Format settings were configured to display “Open Content Referral Link” or “Open Content Referral Link, fallback to the Appspace“, a web browser is launched to display the content referral link when the post title or thumbnail is clicked in the Webex chat room window. If however, the referral link fails to be displayed, the viewer/user will be redirected to the Employee Experience.
Unpublish Content from Webex Chat Room
Appspace Account Owner/Publisher permissions are required.
The instructions below show you how to unpublish content to the Webex chat room.
  2. Select the playlist channel, which has been published to a Webex app.
  3. In the Edit tab, select the desired content, and click the enterprise messaging app icon.
  4. Click Remove post from all apps to remove the content from the chat room.
Unpublish Webex App from Channel
The instructions below show you how to remove the published playlist channel from Webex chat room.
  3. Click the Publish tab, and click the Delete icon next to the selected Webex chat room.
  4. Click OK to confirm the removal.
Delete Webex Authentication from Appspace
The instructions below show you how to delete the Webex enterprise messaging app integration from Appspace.
  1. Click the ☰ Appspace menu, and select Integration, and click the Passports tab.
  2. Click the ellipsis for the desired Webex integration, and click Delete.
  3. Click OK to confirm deletion.
