Question
I need to ,cerate a Dashboard in Appspace showing WebEx calls & meetings and Video mesh conferences statistics
  • May 24, 2026 8:37 AM UTC
  • 1 reply
  • 76 views
The challenge  is that we do have multi factor authentication and I need to create the card with Embedded  account credentials  , using power PI is the last opation to try ...any ideas ?
1 reply
Dawn Wayland
Forum|alt.badge.img+8
  • Community Manager
  • May 27, 2026 1:54 PM UTC
​@Nazar to better understand your environment and identify the best path forward, we’d recommend opening a support case. This will allow us to review the specific authentication method being used and explore alternative solutions if needed.
Based on your description, it’s possible this is a custom implementation using embedded credentials rather than standard basic authentication, so we’ll want to take a closer look at the configuration details.
