Supported Appspace Cards
  • Jul 4, 2025 1:48 AM UTC
  • Sep 30, 2026 6:54 AM UTC
  • 1305 views
Appspace cards are HTML5-based templates available in the Library that you can use to create engaging, interactive content. Versatile and easy to create using the available themes in the Appspace console, cards support a wide variety of content, including images, text, video, data, and more. Cards are an easy but powerful medium to create the desired messaging ideal for any type of information needed for digital signage and workplace initiatives. However, you must check the device (and model) compatibility for every card prior to installing.
All cards are officially created by Appspace. Most of our cards receive periodic updates, new templates, and enhanced features from Appspace, and are known as Appspace supported cards. We also have cards that are developed in collaboration with vendors, and cards that are initially developed by Appspace but customized and supported by a third-party community developer using Appspace card APIs — these are known as community cards.
In this article, we have categorized cards based on the different experiences that they are ideal for, as follows:
Important:
  • Please refer to this article to confirm supported device models: Supported Devices & Operating Systems
  • Cards are only supported on devices compatible with the Appspace App. Legacy devices are not supported.
  • All cards are Appspace supported cards unless specified otherwise.
  • Some collaboration platforms (for example Neat, Poly, Logitech, or Employee View) may appear on an individual card’s release notes. Those platforms are not rows in the tables below unless listed.
Note:
  • LG: It is recommended that animations be turned off as LG devices have performance issues with transitions.
  • BrightSign:
    • It is recommended that video be added only in the feature media component and not in the background.
    • We also recommend adding only one (1) video in each card, as BrightSign only supports one video layer at a time.
    • When video is added to the feature media, border formatting will not be applied.
    • While BrightSign HD devices support cards, animation performance may be affected.
  • Refer to Supported Content & Device Capabilities to view other device capabilities.
Communication & Messaging
The following cards are ideal for signage or employee communications, for displaying:
  • Alert card – important or critical messages immediately or at a scheduled time, taking over current content momentarily.
  • Announcement card – ideal for displaying corporate messages, announcements, wallpapers, and signage, with interactivity and transitions.
  • Counter card – ideal to display a count-down or count-up timer with a message.
  • Milestone card – to display multiple occasions or milestones in advance, each with its own messaging, event type, and display dates.
  • Banner card – to display a banner, ideal when used on the 5-zone channel playlist.
  • SharePoint card – to display SharePoint content.
  • Beezy Stories card and Beezy Hero card – to display Appspace SharePoint Intranet (Beezy) content.
  • Generate card – create branded visual messaging from a text prompt with Appspace Intelligence. See Cards: AI Generate Card. A full operating-environment matrix is not yet recovered for this table; refer to Generate Card Release Notes for known device playback limitations.
Operating Environment
Alert
Announcement
Counter
Milestone
Banner
SharePoint
Beezy
Android
BrightSign
✔ 1
Chrome OS
Cisco Collaboration Endpoints (CE) - Signage Mode
Cisco Webex Share
Crestron
✔ 3
iOS
LG WebOS
✔ 4
MacOS
MediaVue
Mersive
Samsung SSP / Tizen
✔ 2
✔ 4
Ubuntu Linux
Universal Windows Platform (UWP)
Windows
IAdea
Note:
  • Existing Appspace Announcement card templates (prior to September 22 2018) will be disabled by default. Administrators may enable it if needed. However, user-created themes will still remain in the Library.
  • 1 Video backgrounds are not supported on the Announcement card for BrightSign devices, as these devices do not support layering on top of videos.
  • 2 Unable to render videos on the Announcement card when displayed on Samsung SSP Tizen devices, due to device limitations.
  • 3 Video backgrounds not supported on Counter card for Crestron devices.
  • 4 Performance issue when displaying the “seconds counter” for the Counter card on Tizen and LG devices.
  • Generate card known playback skips (see Generate Card Release Notes): BrightSign XD1033 (FW 8.4.10); LG webOS 4.0 and 4.1; Tizen 4.0 and 6.5; Crestron AirMedia-200; AOpen Chromebox Commercial 2; ChromeOS Flex; IAdea XMP-8522.
Data & Charts
We currently have these cards to display charts, tables, dashboards, or spreadsheets:
  • Data Visualization card – choose from a myriad of chart types to display such as leaderboard, line, bar, donut, progress bar, and progress donut.
    • Bar Chart
    • Leaderboard
    • Progress Bar Chart
    • Donut Chart
    • Line Chart
    • Progress Donut Chart
  • Table card – display data in a table, either by manually adding the data into the table, or importing it from an Excel spreadsheet.
  • Dashboard card – displays dashboard content from selected providers:
Bar Chart
Leaderboard Chart
Progress Bar Chart
Donut Chart
Line Chart
Table
Power BI
Salesforce
Tableau
Grafana Cloud
Android
✔ 5
✔ 5
BrightSign
✔ 6
✔ 5
Chrome OS
✔ 1
✔ 1
Cisco Webex Share
Crestron
✔ 2
✔ 2
✔ 7
IAdea
iOS
✔ 4
✔ 4
LG WebOS
✔ 5
✔ 5
MacOS
MediaVue
✔ 3
✔ 3
Mersive
✔ 4
✔ 4
Samsung SSP / Tizen
✔ 5
✔ 5
Ubuntu Linux
✔ 4
✔ 4
Windows
Note:
  • 1 Unable to display Advanced Channels in Channel Browsing mode on the Appspace App. *(Applies to Power BI / Salesforce cells marked 1.)*
  • 2 Channel Browsing mode is not supported on Crestron AirMedia and Mercury devices. *(Applies to Power BI / Salesforce cells marked 2.)*
  • 3 Only supported on MediaVue SureVue D2 devices. Unable to display Advanced Channels in Channel Browsing mode. *(Applies to Power BI / Salesforce cells marked 3.)*
  • 4 Unable to display playback for 24 hours. *(Applies to Power BI / Salesforce cells marked 4.)*
  • 5 Supported via Power BI Dashboard Screenshot service.
  • 6 BrightSign devices running firmware version 8.5 and above support displaying the Live Power BI Dashboard, while BrightSign devices running firmware version 8.4 and below support the Power BI Dashboard Screenshot service.
  • 7 Grafana Cloud on Crestron: validated on TSW / TSS / selected AirMedia models in the Grafana Card 1.0.0 device matrix; Mercury was not marked supported in that matrix.
Content Feeds
  • Google Sheets card – a Google Sheets spreadsheet directly on your card using a link to your file.
  • Google Slides card – a Google Slides presentation directly on your card using a link to your file.
  • Microsoft PowerPoint card – PowerPoint presentations stored in OneDrive or SharePoint via a Microsoft 365 Drive Passport. See Cards: Display Microsoft PowerPoint Presentations.
  • RSS card – one or multiple RSS feeds.
  • Weather card – local weather conditions.
  • Web View card – contents from an external website on the card with multiple embedding options available.
  • Webex Recording card – recorded Cisco Webex Meetings.
  • World Clock card – current time of up to eight cities simultaneously.
  • Zoom Recording card – recorded Zoom Meetings.
  • Financial card – financial feeds from selected providers.
  • Quotes Feed card – displays a quote, ideal when used on the 5-zone channel playlist.
Google Sheets
Google Slides
RSS Feeds 1
Weather
Web View
Webex Recordings
World Clock
Zoom Recordings
Financial
Quotes Feed
Android
BrightSign
Chrome OS
✔ 2
Cisco Webex Share
Crestron
✔ 3
IAdea
iOS
LG WebOS
MacOS
✔ 4
MediaVue
Mersive
Samsung SSP / Tizen
Ubuntu Linux
Windows
Note:
  • 1 Supported RSS formats: RSS 1.0, RSS 2.0, mRSS, Atom 1.0.
  • 2 Microsoft PowerPoint: validated on Cisco Webex Board in the PowerPoint Card 1.0.0 device matrix; other CE / RoomOS models in that matrix were not marked supported.
  • 3 Microsoft PowerPoint on Crestron: validated on TSW-1060, AirMedia 3200, and Mercury in the 1.0.0 matrix; TSS-770 and AirMedia 200 / 300 / 3100 were not marked supported.
  • 4 Microsoft PowerPoint on MacOS: validated on Electron desktop (Mac Mini) in the 1.0.0 matrix.
Premium Content Feeds
The premium content cards listed below require content license subscriptions, and display the following:
  • Industry Feeds card – general workplace and industry-critical content feeds (general workplace feeds & vertical-specific feeds) from Appspace.
  • Industry Content Collection card – browse and select on-demand industry-critical content feeds from an archive of previously streamed content from Appspace.
  • News card – news from multiple news providers, some of which are premium news providers, and only available to customers with an active premium license subscription.
  • Local Health Conditions card – UV, Pollen, or Air Quality Indexes for a selected location.
  • Weather Radar card – track progressive weather conditions by displaying an interactive regional or national weather radar map.
Industry Feed
News
Local Health Conditions 1
Weather Radar 2
Android
BrightSign
Chrome OS
Cisco Webex Share
Crestron
✔ 3
✔ 3
IAdea
iOS
LG WebOS
MacOS
MediaVue
Mersive
Samsung SSP / Tizen
Ubuntu Linux
Windows
Note:
  • 1 Please see Limitations listed in the Local Health Conditions Card Release Notes.
  • 2 Please see Limitations listed in the Weather Radar Card Release Notes.
  • 3 Only supported on Crestron Mercury devices.
Social Media Feeds
The cards ideal for displaying content from social media platforms, as follows:
  • Facebook – posts and hashtags from the Facebook platform.
  • Instagram – posts and hashtags from the Instagram platform.
  • YouTube – YouTube videos with customizable video resolutions.
  • Vimeo – display on digital signage any public video content hosted on the Vimeo platform.
Facebook
Instagram
YouTube
Vimeo
Android
BrightSign
Chrome OS
Cisco Webex Share
Crestron
IAdea
iOS
LG WebOS
MacOS
MediaVue
Mersive
Samsung SSP / Tizen
Ubuntu Linux
Windows
Workplace Room Scheduling
These room scheduling cards are ideal for displaying the Appspace room, resource, or desk booking app with schedules, maps, and real-time booking capabilities on touch-screen panels:
  • Schedule Board card – for displaying the schedules of multiple rooms (with or without maps) in an organization on large TVs or digital boards.
  • Room Booking card – for single-room scheduling, with devices placed outside conference rooms for instant touch-screen bookings.
  • Desk Booking card – to display QR code desk booking for Qbic devices for Appspace reservations.
  • Visitor Kiosk card – for kiosk check-ins with the Appspace Visitor Management system.
Schedule Board Card
Room Booking Card
Desk Booking Card
Visitor Kiosk Card
Android
BrightSign
✔ 1
✔ 1
✔ 1
Chrome OS
Cisco Webex Share
Crestron
✔ 2
✔ 2
✔ 2
IAdea
iOS
LG WebOS
✔ 1
✔ 1
✔ 1
MacOS
MediaVue
✔ 1
✔ 1
✔ 1
Mersive
Samsung SSP / Tizen
Ubuntu Linux
Windows
Qbic - TD-0350
Note:
  • 1 Interactivity is not supported on BrightSign, LG, and MediaVue devices, thus only the meeting room information is displayed, while bookings must be done via the calendar.
  • 2 Only supported on Crestron TSS.
Checkpoints
Checkpoint cards are form-based checkpoints used with Space Reservation and Visitor Management. Themes include Legal Document, Questionnaire, and Reservation Services. See Checkpoint Cards: Display Checkpoint Form.
Checkpoint Card
Android
BrightSign
Chrome OS
Cisco Webex Share
Crestron
IAdea
iOS
LG WebOS
MacOS
MediaVue
Mersive
Samsung SSP / Tizen
Ubuntu Linux
Windows
Note:
  • Device rows other than Android and iOS are marked unsupported based on the published Checkpoint Card Release Notes supported-devices list. Expand this matrix if a later Checkpoint RN documents additional platforms.
Community
Important:
Community cards are initially created by Appspace, but are customized and supported by a third-party community developer using Appspace card APIs. Contact us to learn more about our developer community. Community cards will be turned off by default.
We currently have the following community card available:
  • Social Media by Seenspire card – display real-time social media feeds available through a Seenspire subscription account.
Social Media by Seenspire Card
Android
BrightSign
Chrome OS
Cisco Webex Share
Crestron
IAdea
iOS
LG WebOS
MacOS
MediaVue
Mersive
Samsung SSP / Tizen
Ubuntu Linux
Windows
