Tactics and Talks
Building Engagement: Small, Intentional Steps for Lasting Impact on Your Intranet
  • Apr 29, 2026 2:30 PM UTC
  • 63 views
Bradley Rooke
Forum|alt.badge.img+3
Engagement gets talked about like it’s some elusive spark - something you either have or you don’t. In reality, it’s far less mysterious than that. Engagement on your intranet isn’t magic, it’s intentional. More often than not, it’s shaped by small, deliberate choices that either invite people in or quietly push them away.
The mistake many teams make is aiming for a big bang moment: a major launch, a shiny new feature, a campaign that’s meant to “fix” engagement overnight. Those moments have their place, but they rarely stick on their own. What actually moves the needle are the subtle, consistent signals that tell people, “this space is for you, and it’s worth your time.”
That can be as simple as how content is framed. A headline that speaks like a human instead of a policy document. A post that asks a question instead of just broadcasting information. A quick reaction or comment from a leader that shows someone is actually listening. These aren’t heavy lifts, but they shift the tone from static to social.
There’s also something to be said for visibility. If participation feels like it disappears into a void, people stop bothering. But when contributions are acknowledged - even briefly - it reinforces the behaviour you want to see. A reply, a like, a follow-up post that builds on someone’s input: these are small cues that create momentum.
We also need to consider friction. Every extra click, every unclear pathway, every “where do I even post this?” moment chips away at participation. Boosting engagement sometimes has less to do with adding features and more to do with removing obstacles. When it’s easy to contribute, more people will.
The common thread in all of this is intention. You don’t need a complete overhaul to improve engagement, you need to start small and stay consistent. A slight shift in tone, a more human approach to interaction, a bit more responsiveness. Do that well, and those small changes compound into something much bigger.
Remember: in the end, engagement isn’t something you switch on. It’s something you build quietly, deliberately, and over time.
