Appspace Supported Browsers, Allowed URLs & Ports
  • June 26, 2025
  • 2574 views
This article outlines the minimum requirements for running the Appspace platform  on browsers or mobile devices.
Supported Browsers
Listed below are the supported web browser versions on the server and for client machines used to access the Appspace platform.
Browser Microsoft Windows Mac OS
Chrome 89.0.4389.114 (64bit) 89.0.4389.114 (64bit)
Firefox 87.0 87.0
Microsoft Edge 89.0.774.63
Safari 14.0.3
Additional Requirements:
  • Disable pop-up blocker.
  • Minimum screen resolution of 1024 × 768 is recommended.
Browser versions prior to the ones listed above have not been tested on the latest version of Appspace, and may have limited functionality.
Internet Explorer 11 is no longer supported:
  • Please be advised that due to the termination of Microsoft Support, Internet Explorer 11 will no longer be supported as of June 15, 2022.
  • If using applications that require this compatibility, users may use Edge in Internet Explorer Mode, but Appspace will no longer support Internet Explorer 11.
Required URLs List
Configure your network, firewall, or proxy servers to allow access to the following sites:
  • https://*.appspace.com
  • https://*.appspaceusercontent.com
  • https://*.appspacestatic.com
  • Any external NTP server (alternative to using an internal NTP server)
  • Any external content sources (e.g RSS feeds and websites.
  • https://www.worldweatheronline.com/ (World Weather Online) – Mandatory if weather forecasts are for countries outside the US.
When using BrightSign to manage your players, you need to whitelist specific URLs and ports for the players to communicate with the cloud services. You can find that information here for BrightSign: https://docs.brightsign.biz/advanced/bsn-ports-and-urls
Firewall Ports
Configure your firewall to enable access to the following ports for seamless delivery of Appspace.
Required
  • HTTPS (443) – HTTPS port 443 open towards Appspace server(s).
Optional
You may configure your firewall to allow access to the following ports only if necessary:
  • UDP (123) – For access to NTP packages.
  • TCP/UDP (53) – For access to a DNS server.
  • TCP/UDP 8884 – Application Networking Manager (ANM) trusted communications if using ANM. On Assured Platform SureVue devices only.
  • TCP/UDP (8885-8887) – SureVue mesh networking and ANM communication. On Assured Platform SureVue devices only.
  • TCP/UDP (9090) – Chromium debugging services. The port is open by default, but the listening service is disabled. On Assured Platform SureVue devices only.
