Question
Visitor Management + Wireless Connection Issues
  • Jun 9, 2026 1:57 PM UTC
  • 1 reply
  • 67 views
We continue to have issues with inconsistent printing after a visitor checks in.  Often times they can’t complete the check in process before they get booted back to the check in screen or the guest checks in but a badge won’t print. We’ve worked with tech support but I thought while we waited I’d see if anyone else has experienced issues. Does anyone have their VM devices (ipad/printer) connected differently?
1 reply
Dawn Wayland
Forum|alt.badge.img+8
  • Community Manager
  • Jun 9, 2026 4:08 PM UTC
​@kbannis
Thank you for sharing your experience. We understand how disruptive inconsistent check-in and badge printing issues can be, especially when it impacts the visitor experience.
We can confirm that a support case has been opened and the issue has been escalated to our Engineering team for investigation. We are actively tracking this and working to understand the root cause.
At this time, we have not received other reports describing the same behavior, which makes gathering additional details especially important. If other community members have experienced similar issues—whether related to visitor check-in unexpectedly returning to the welcome screen, badge printing failures, or specific iPad/printer/VM connectivity configurations—we would encourage you to share your setup and observations here.
In the meantime, thank you for your patience as our teams continue to investigate. We understand the impact this is having on your operations and will provide updates as we learn more.
