Solved
Anyone having issues accessing Device page within AppSpace?
  • Apr 29, 2026 5:47 PM UTC
  • 2 replies
  • 169 views
Hello all,
Wondering if anyone else is experiencing issues when trying to access the Device tab within AppSpace? My team and I have been unable to access this for the last few days with little to no response from the support team or our customer success person.
Thanks!
Best answer by Dawn Wayland
​@dwight I appreciate you sharing those details. I know it’s difficult to manage your network when the Devices tab isn't responding as expected.
To provide an update on the technical side: our public cloud experienced a performance degradation. The engineering team has since deployed a fix, and the incident is currently in a Monitoring stage. While performance is recovering, some slowness may still occur when accessing the Devices page, as it requires significant resources to load.
You can follow the real-time recovery progress here: status.appspace.com.
To help narrow down whether the current slowness is tied to this recovery or something local, could you provide a bit more information?
  • Current Behavior: When you attempt to open the Devices tab, do you see a spinning loader, a blank page, or a specific error code?
  • Browser Details: Which browser and version are you using? (Testing in an Incognito/Private window is also a great way to rule out local cache issues).
  • Network Check: It is also worth verifying that no recent local network or firewall changes are blocking Appspace-required URLs or ports.
Since the fix was deployed and the status moved to Monitoring, have you noticed any change in the page behavior, or is it still behaving the same as it was?
View original
Dawn Wayland
Forum|alt.badge.img+9
  • Community Manager
  • Answer
  • Apr 29, 2026 6:36 PM UTC
  • Author
  • Explorer
  • Apr 29, 2026 8:36 PM UTC
Everything now seems to be operational. Thanks for the update.
