Appspace’s new Posts Management module streamlines content management by offering a unified platform for all post types, from Stories and Pages to User Posts, Questions, Polls, and Praises. It features an intuitive interface that simplifies CRUD operations, which stands for Create, Read, Update, and Delete. This means administrators can easily create new posts, read and review existing ones, update content as needed, and delete outdated or irrelevant posts. With advanced filtering options, finding and managing specific content becomes a breeze. This centralized approach, coupled with efficient moderation tools, empowers administrators to maintain high-quality content that aligns with community guidelines and brand standards, ultimately enhancing productivity and user experience.
This article provides administrators with the instructions to create and manage posts in the Posts Management module.
What's New
Features released in Appspace 8.8.0-ac.2 Lynx
- The Posts Management module is available in the Admin Console.
Create and Configure Posts
Follow the instructions below to create and configure posts.
- Click the ☰ Appspace menu, and select Posts.
- On the Posts dashboard, click on the Create button to start create the following.
- Post – To create and publish post, proceed to the Create Post section of the article Create Quick Post in the Employee View.
- Story -To create and publish a story, proceed to the Create Story section of the article Create Stories in the Employee View.
- Page – To create and publish a page, proceed to the Create Page section of the article Create Pages on the Employee App.
- Event – To create an event, proceed to the Create Event Post and Event Reservation section of the article Create Quick Post in the Employee View.
- (New) Question – To create a question post, proceed to the Create and Manage Questions on the Employee View article.
- (New) Poll – To create a poll, proceed to the Create and Manage Polls in the Employee View article.
- Praise – For praises and messages, proceed to the Send Praise section of the article Create Quick Post in the Employee View.
Edit Posts
Follow the instructions below to edit a post.
- On the Posts dashboard, to edit the post, you may do the following:
- Select the desired post and click on the ellipsis (…) and select Edit.
- Another way to edit the post is to select the desired post, click on the ellipsis (…), and then choose from the following options:
- Edit
- Preview
- Copy Link
- Feature / Unfeature
- Unpublish
- Reschedule
- Update tags
- Update spaces
- Change author
- Archive
- Delete
Bulk Update Posts
(New) Besides editing single posts, you can also select multiple posts from the Posts dashboard and update them at the same time.
- On the Posts dashboard, select the checkbox for each post that you want to update. The multi-select toolbar appears when multiple posts are selected. Only actions that apply to every selected post type are available. Edit-dependent actions are hidden when you do not have edit access to the selected content.
- From the multi-select toolbar, select one of the following actions:
Feature/Unfeature – Mark the selected posts as featured or remove their featured status.
Unpublish – Return the selected published posts to Draft status. The posts remain available for editing.
Reschedule – Set or update the publication date and time for the selected posts.
Update Tags – Add tags to the selected posts or replace their existing tags.
Update Spaces – Add the selected posts to Spaces, remove them from Spaces, or replace their existing Space assignments.
Change Author – Assign a different author to the selected posts. Secondary authors are included when applicable.
Archive – Remove the selected posts from active post listings while preserving them for later access.
Delete – Remove the selected posts from Appspace. This action cannot be undone.
In the action window, configure the required settings.
Review the selected action and settings, and click Save or Confirm to apply the changes.
Review the progress and results displayed for the selected posts. The results identify which posts were updated successfully and which posts could not be updated.
