Sticky
Configuring and Managing Device Settings in the Appspace Console
  • September 30, 2025
  • 1264 views
In the Appspace Console, Device Settings is a centralized module for administrators to configure and manage Appspace-powered devices. This section provides detailed control over individual device behaviors and enables the application of universal settings across device groups or locations. It is essential for optimizing device performance, ensuring content delivery, and maintaining the operational integrity of digital signage, room scheduling, and kiosk deployments.
This article provides administrators with instructions on how to configure and manage device settings within the Device Settings module.
Prerequisite
Configure and Manage Devices Settings
The instructions below detail how to configure and manage device settings within the Appspace Console.
  1. Log in to your Appspace console.
  2. Click the ☰ Appspace menu, and select Devices from the menu.
  3. On the Devices dashboard, click Settings.
  4. From the Devices Settings dashboard, users can configure options across three main tabs:
    • Global
    • Downloads
    • Locations
Global Settings
General
The instructions below detail how to configure and manage general settings within the Appspace Console.
  4. In Global > General, you can perform the following actions:
    • Toggle the Enable Registration Recovery switch to ON to enable the Persistent Device Registration feature.
    • Manage software update settings by device type through Software Updates. By default, software updates are disabled (OFF) for BrightSign and Qbic devices, and enabled (ON) for Tizen, MacOS, and Windows devices. Account Owners can enable or disable software updates for supported device types at the global account level.
    Persistent Device Registration automatically recovers lost registration information, identity, and configuration settings for devices. It uses a unique hardware identifier such as a serial number or MAC address.
Integrations
The instructions below detail how to configure and manage integrations settings within the Appspace Console.
  4. In the Global > Integrations, click the +Add button.
  5. New Device Integration popup modal appears.
Downloads Settings
The instructions below detail how to configure and manage download settings within the Appspace Console.
  4. In the Downloads tab, users will see a list of device installers, including the device Name, Version, Published date, and Action options.
  5. To download a desired device installer, select Download in the Action column next to the relevant device.
  6. In the Download Confirmation window, click Download to proceed. Users can click Cancel to abort the download.
Locations Settings
The instructions below detail how to configure and manage location settings, including default channels, permissions, translation languages, software updates, fallback content, operating hours, properties, and notifications.
  4. In the Locations tab, users may configure settings for the selected location.
Overview
  • My Location –  Set the desired devices location and sub-locations.
  • Name –  Name the desires location.
  • Description – Add a description about the location.
  • Default Channel – User may select the option of the default channel; not assigned, autoplay all channels, admins assign a single channel and users published channels.
  • Permissions – Assign permissions; location admin or publisher, and click Save.
  • Translation Languages - Users can select their preferred language from a list of 33 Appspace-supported languages for translated content.
    Notes:
    Admins can deselect English as long as at least one other language is selected; if no language is selected, the system automatically defaults back to English to ensure a valid configuration.
    Notes:
    This setting is only available for AI-generated cards that use the multilingual translation services.
  • Software Updates – The software update times are based on the device’s local time. To configure software updates, select one of the following options:
  • Fallback Content  - The Fallback Content setting defines the media that displays when assigned content is unavailable or cannot be played on devices assigned to the location.
    • Select one of the following options:
      • Inherited – Uses the fallback content configuration from the parent location.
      • None – No fallback content is configured for the location.
      • Media – Displays selected media as fallback content.
If Media is selected, choose the image or video content to use as fallback content, then enter the Content Duration, if required.
Note:
Fallback content can be inherited from a parent location. If a child location does not have its own fallback content configuration, devices assigned to that child location use the fallback content configured for the parent location.
  • Operating Hours  - The Operating Hours setting defines operating hours to control screen behavior outside business hours.
    • None – No schedule set.
    • Manual – Set custom hours; the user must define the operating hours. To do this, click Define Operating Hours. In Define Operating Hours, users can:
      • Click the time Option to choose from Hour30 mins15 mins, or 1 min.
      • Select the desired Day or choose Everyday.
      • Once completed, click Apply.
      • To make changes, click Edit Hours and repeat the steps.
      • To delete a schedule, click the Remove Schedule button.
  • Inherited – Apply hours from the parent location.
  • Inherited (Automatic Updates) – Settings automatically apply from the parent source.
  • Automatic Updates – Install software updates automatically at a specified time every day.
    Notes:Automatic app updates are supported on BrightSign, Tizen, and Windows/Mac Electron devices.
  • Manual Updates – Manually initiate software updates at your convenience by selecting the Schedule Update button.
  • App Version – Lock a device to a specific app version for stability and control. To configure the App Version, follow these steps:
    • Click App Version.
    • In the Select App Version popup, click Add Device Type.
    • Select the desired device and choose the version.
    • Click Save.
      Note:
      • If software updates for Qbic devices are disabled globally, the following message is displayed at the location level:
        • Software updates for Qbic devices are disabled globally. Contact your admin or adjust Global Device Settings to enable.
      • If a device or location is pinned to an unsupported app version, it is highlighted, and a tooltip displays on hover:
        • The pinned app version is no longer available. Please select an alternative version.
Properties
In the Properties, the following actions may be performed:
  • Add a property by clicking the +Add button.
  • In Add Property, enter the desired Name and Value, then click Save.
  • To edit a property, click the Ellipsis (…), then select Edit. Only the Value of the property can be changed. Once completed, click Save.
  • In the Notifications, the following actions may be performed:
    • Add a notification by clicking the +Add button.
Notifications
In Add Notification, configure the following fields:
  • Name: Enter the desired name for the notification.
  • Notification Type: Select the desired type –
    • Live Alert: Triggers immediately after an event.
    • Summary: Provides timely reports on network status.
  • Location: Select the desired location. The checkbox Include sub-locations may also be selected.
  • Trigger from: Select the desired time or check All Day.
  • Timezone: Select the desired timezone. The checkbox Recipients Inherit Selected Timezone may also be selected.
  • Recipients: Add the desired recipients. Once all details are entered, click Save.
  • To delete a notification, click the Ellipsis (…), then select Delete.
