Custom Widgets Developer Guide: Advanced
  • April 2, 2026
  • 201 views
This supplemental guide covers how to build custom widgets that integrate with third-party services using Passports — Appspace's mechanism for managing authentication with external providers like Google, Microsoft, Zoom, Slack, and more.
In this article:
Prerequisites:
Before reading this guide, complete the Custom Widget Developer Guide to understand the basics of widget creation, the Widget API, and schema configuration.
What Are Passports?
A Passport in Appspace is a secure authentication connector that allows your widget to communicate with third-party services. Instead of managing OAuth tokens directly in your widget code, Passports handle the entire authentication lifecycle:
  1. Administrator connects the Passport (OAuth popup)
  2. Appspace stores the credentials securely
  3. Your widget calls callAuthenticatedAPI() — the Console injects the correct auth headers automatically
  4. Token refresh is handled transparently by Appspace
Your widget code never sees the actual credentials. It only sends API requests by name, and the Console proxies them with the correct authentication.
Two Approaches to Authentication
When your widget needs to talk to a third-party service, you have two options:
Approach When to Use What Happens
Built-in Passport
The service already has an Appspace Passport (Google, Microsoft, Zoom, etc.)
Administrator selects an existing Passport from a dropdown in the widget configurator
Custom (Embedded) Passport
The service is not in Appspace's built-in list, or you need custom OAuth configuration
You bundle a passport/*.json file in your widget ZIP; Appspace auto-creates the Passport on upload
Both approaches use the same Widget API method (callAuthenticatedAPI) at runtime. The only difference is how the Passport is provisioned.
Approach 1: Using Built-in Passports
If the third-party service already has an Appspace Passport, your widget can reference it without bundling any passport file. The administrator will select an existing Passport when configuring the widget.
Step 1: Add authentications to schema.json
"authentications": [
"label": "Google Calendar",
"authenticationType": "passport",
"authKey": "googleCalAuth",
"metadata": {
"passportProvider": "google"
The passportProvider value tells the widget configurator which Passports to show in the dropdown. See the Built-in Passport Reference for all available values.
Step 2: Add authenticatedApis to schema.json
"authenticatedApis": [
"label": "Get Calendar Events",
"name": "getCalendarEvents",
"url": "https://www.googleapis.com/calendar/v3/calendars/primary/events",
"method": "GET",
"authenticationKey": "googleCalAuth",
"headers": {
"Authorization": "Bearer {authorization.googleCalAuth.token}"
Step 3: Call the API from your widget
var response = await window.appspace.widgetApi.callAuthenticatedAPI('getCalendarEvents', {
params: { maxResults: '10', orderBy: 'startTime', singleEvents: 'true' }
if (response.status === 200 && response.data && response.data.isSuccess) {
var events = response.data.body; // Parsed JSON
Important: Only pass params. Do not pass method, headers, or body — these are defined in the schema and handled by the proxy.
What the administrator sees
When configuring the widget, the administrator sees a dropdown listing all Passports matching the passportProvider value. They select one (or create a new one) and connect it.
Approach 2: Bundling a Custom Passport
When your target service is not in the built-in list, or you need specific OAuth scopes, bundle a Passport JSON file inside your widget ZIP.
Step 1: Create the passport JSON file
Create a file in the passport/ directory of your widget project.
OAuth Example — passport/my-api-connector.json:
"name": "My API Connector",
"applicationName": "custom",
"authenticationType": "OAuth",
"isCustomApplication": true,
"customApplicationInfo": {
"name": "my-api-connector",
"displayName": "My API Connector",
"description": "OAuth connector for My API service",
"categoryType": "Custom",
"parentName": "custom",
"metadata": {
"clientId": "<your-client-id>",
"clientSecret": "<your-client-secret>",
"authenticationUrl": "https://api.example.com/oauth/authorize",
"tokenUrl": "https://api.example.com/oauth/token",
"profileUrl": "https://api.example.com/api/me",
"profileAccountEmailPath": "$.email",
"profileAccountIdPath": "$.id",
"profileAccountNamePath": "$.name",
"scope": "read write"
"metadata": {}
Step 2: Reference in schema.json
Add the passport property to your schema and wire up authentications and authenticatedApis:
"passport": {
"filePath": "passport/my-api-connector.json"
"label": "My API Authentication",
"authKey": "myApiAuth",
"metadata": {
"passportProvider": "custom:my-api-connector"
"label": "Get Data",
"name": "getData",
"url": "https://api.example.com/v1/data",
"method": "GET",
"authenticationKey": "myApiAuth",
"headers": {
"Authorization": "Bearer {authorization.myApiAuth.token}"
Critical: The passportProvider value must follow the pattern custom:<name> where <name> matches customApplicationInfo.name in your passport JSON file.
Step 3: Include passport in your ZIP
Ensure your packaging script includes the passport/ directory:
// In scripts/package-widget.js
if (fs.existsSync('passport')) {
archive.directory('passport/', 'passport');
Or if zipping manually, include the passport/ folder in the ZIP alongside widget.html and schema.json.
What happens on upload
When you upload the widget ZIP to Appspace:
  1. The backend reads schema.json and finds passport.filePath
  2. It extracts the passport JSON from the ZIP
  3. It automatically creates a custom Passport in the Appspace passport service
  4. The widget configurator shows the passport pre-selected for the administrator
  5. The administrator completes the OAuth connection flow
Instead of a dropdown, the administrator sees a dedicated "Connect" button for the bundled passport. After connecting (OAuth popup), the button shows the connected status with options to reconnect or disconnect.
Schema Configuration for Authentication
The three schema properties work together:
passport (optional)          → Bundles a passport JSON for auto-creation
authentications (required) → Declares what authentication the widget needs
authenticatedApis (required) → Defines the actual API endpoints to call
The passport property
Field Type Required Description
filePath
string
Yes
Relative path to passport JSON inside the widget ZIP
Only needed for custom (embedded) passports. Omit this entirely when using built-in passports.
The authentications array
Each entry declares one authentication requirement:
label
string
No
Display label in widget configurator
authenticationType
string
Yes
Must be "passport"
authKey
string
Yes
Unique key to reference this auth (used by authenticatedApis)
metadata.passportProvider
string
No
Filters which passports are shown. Use "custom:<name>" for bundled, or a built-in provider value
metadata.passportType
string
No
Informational: "oauth2"
metadata.adminSitePermission
boolean
No
Whether admin-level site permissions are required
The authenticatedApis array
Each entry defines one API endpoint:
label
string
Yes
Human-readable label
name
string
Yes
Unique name — used in callAuthenticatedAPI(name)
url
string
Yes
Full URL with optional {param.*} template variables
method
string
Yes
"GET", "POST", "PUT", or "DELETE"
authenticationKey
string
Yes
Must match an authKey from authentications
headers
object
No
Static headers. Use {authorization.<authKey>.token} for auth
data
object
No
Static request body for POST/PUT
Making Authenticated API Calls
Once authentication is configured, making API calls is straightforward:
// Call by the 'name' defined in authenticatedApis
var response = await window.appspace.widgetApi.callAuthenticatedAPI('getData', {
params: {
userId: '12345',
limit: '50'
// Response structure
// response.status — HTTP status code (e.g., 200)
// response.statusText — HTTP status text (e.g., "OK")
// response.data.statusCode — Backend status code
// response.data.body — Response body (auto-parsed if JSON)
// response.data.headers — Response headers
// response.data.contentType — Response content type
// response.data.isSuccess — Boolean indicating success
var data = response.data.body;
// Use the data...
Key rules:
  • Only pass params — do not pass method, headers, or body
  • The params object is used for URL template variable substitution and query parameters
  • The Console proxy handles authentication header injection, URL construction, and the actual HTTP request
  • If the API returns JSON, response.data.body is automatically parsed
Template Variables in API URLs
API URLs support template variables that are resolved at call time:
"url": "https://api.example.com/users/{param.userId}/posts?page={param.page}",
"method": "GET",
When calling:
await window.appspace.widgetApi.callAuthenticatedAPI('getUserPosts', {
params: { userId: '42', page: '2' }
The resolved URL becomes: https://api.example.com/users/42/posts?page=2
Special variables
Variable Pattern Source
{param.*}
From the params object passed to callAuthenticatedAPI()
OAuth token for the specified auth key (injected by proxy)
{system.userId}
Current user's ID (injected by host)
Google
Passport passportProvider Auth Type Category
Google Calendar
"google"
OAuth
Calendar
Google Drive
"google"
OAuth
Library
Google Meet Conferencing
"google"
OAuth
Conference
Microsoft
Microsoft 365
"microsoft"
OAuth
Calendar
Microsoft Teams
"microsoft"
OAuth
Publishing
Microsoft Teams Conferencing
"microsoft"
OAuth
Conference
Power BI
"microsoft"
OAuth
Dashboard
SharePoint
"microsoft"
OAuth
Library
SharePoint Publishing
"microsoft"
OAuth
Publishing
Microsoft Viva Engage
"microsoft"
OAuth
Publishing
Microsoft Entra ID
"microsoft"
OAuth
Org Chart
Microsoft 365 Presence
"microsoft"
OAuth
Presence
Microsoft 365 Calendar Permission
"microsoft"
OAuth
Delegations
Appspace SharePoint Intranet
"microsoft"
OAuth
Library
Zoom
Zoom Meetings
"zoom"
OAuth
Library
Zoom Conferencing
"zoom"
OAuth
Conference
Webex
Webex Teams
"webex"
OAuth
Publishing
Webex Meetings
"webex"
OAuth
Library
Webex Conferencing
"webex"
OAuth
Conference
Social & Publishing
Facebook
"facebook"
OAuth
Social
Instagram
"facebook"
OAuth
Social
Slack
"slack"
OAuth
Publishing
Workplace (Facebook)
"workplace"
OAuth
Publishing
Other Services
Salesforce
"salesforce"
OAuth
Dashboard
Tableau
"tableau"
Custom Auth
Dashboard
ServiceNow
"servicenow"
OAuth
Library
Box
"box"
OAuth
Library
Note:
When using a built-in passport, you do not need a passport property or passport/ directory in your widget ZIP. The administrator selects an existing Passport from the dropdown when configuring the widget.
Custom Passport JSON Reference
When bundling a custom passport, the JSON file must follow this structure:
Required Fields
Field Value Description
name
string
Display name for the passport
applicationName
"custom"
Must be "custom" for widget-bundled passports
authenticationType
"OAuth"
Authentication method
isCustomApplication
true
Must be true for widget-bundled passports
string
Short identifier (used in passportProvider: "custom:<name>")
customApplicationInfo.displayName
string
Human-readable name
customApplicationInfo.description
string
Description text
customApplicationInfo.categoryType
string
Category (typically "Custom")
customApplicationInfo.authenticationType
"OAuth"
Must match parent authenticationType
customApplicationInfo.parentName
"custom"
customApplicationInfo.metadata
object
Auth-specific credentials (see below)
metadata
Additional metadata (typically empty)
OAuth Metadata Fields
clientId
Yes
OAuth application client ID
clientSecret
Yes
OAuth application client secret
authenticationUrl
Yes
OAuth authorization endpoint
tokenUrl
Yes
OAuth token exchange endpoint
profileUrl
No
User profile endpoint (for account display)
No
JSONPath to extract email from profile (e.g., "$.email")
No
JSONPath to extract user ID (e.g., "$.id")
No
JSONPath to extract display name (e.g., "$.name")
scope
No
OAuth scopes (space-separated)
scopeSeparator
No
Scope separator character (default: " ")
referenceApplicationName
No
Inherit OAuth URLs from an existing built-in provider
refreshType
No
"beforeExpiryInMinutes" or "periodicallyInMinutes"
refreshValue
No
Refresh interval in minutes
Complete Examples
Example 1: Microsoft Graph Widget (Built-in Passport)
schema.json (relevant sections):
"label": "Microsoft 365",
"authKey": "msGraph",
"metadata": {
"passportProvider": "microsoft",
"passportType": "oauth2"
"name": "getEvents",
"url": "https://graph.microsoft.com/v1.0/me/calendarview?startDateTime={param.startDate}&endDateTime={param.endDate}",
"method": "GET",
"authenticationKey": "msGraph",
"headers": {
"Authorization": "Bearer {authorization.msGraph.token}"
Widget code:
var now = new Date();
var nextWeek = new Date(now.getTime() + 7 * 24 * 60 * 60 * 1000);
var response = await window.appspace.widgetApi.callAuthenticatedAPI('getEvents', {
params: {
startDate: now.toISOString(),
endDate: nextWeek.toISOString()
var events = response.data.body.value;
events.forEach(function(event) {
console.log(event.subject, event.start.dateTime);
Example 2: Custom OAuth Widget (Bundled OAuth Passport)
A widget that integrates with a custom SaaS API using OAuth.
passport/my-saas-connector.json:
"name": "My SaaS Platform",
"name": "my-saas-connector",
"displayName": "My SaaS Platform",
"description": "OAuth connector for My SaaS Platform API",
"metadata": {
"clientId": "your-client-id-here",
"clientSecret": "your-client-secret-here",
"authenticationUrl": "https://auth.my-saas.com/oauth/authorize",
"tokenUrl": "https://auth.my-saas.com/oauth/token",
"profileUrl": "https://api.my-saas.com/v1/me",
"profileAccountNamePath": "$.display_name",
"scope": "read:data write:data"
"metadata": {}
Troubleshooting
Passport not appearing in widget configurator
Symptom: No passport dropdown or connect button shown.
Solutions:
  1. Ensure authentications array exists in schema.json with at least one entry
  2. Verify authenticationType is "passport" (not "custom")
  3. For built-in passports: verify the passportProvider value matches a known provider
  4. For bundled passports: verify passport.filePath points to a valid JSON file in the ZIP
"Authentication required" error on API call
Symptom: callAuthenticatedAPI() returns an error.
Solutions:
  1. Ensure the administrator has connected the passport
  2. Verify authenticationKey in authenticatedApis matches an authKey in authentications
  3. Check that the passport is active (not expired or revoked)
OAuth connection fails
Symptom: OAuth popup closes without completing.
Solutions:
  1. Verify clientId and clientSecret in your passport JSON are correct
  2. Ensure authenticationUrl and tokenUrl are valid endpoints
  3. Check that the OAuth app's redirect URI includes your Appspace domain
  4. Verify the scope is valid for the target API
API call returns unexpected data
Symptom: response.data.body is empty or malformed.
Solutions:
  1. Verify the API URL is correct (check template variable substitution)
  2. Ensure you're only passing params — not method, headers, or body
  3. Check that the OAuth scope includes permission for the requested endpoint
  4. Look at response.data.statusCode and response.data.headers for clues
Custom passport not auto-created on upload
Symptom: Widget uploads but passport doesn't appear.
Solutions:
  1. Verify the passport/ directory is included in the widget ZIP at the root level
  2. Check that passport.filePath in schema.json matches the actual file path
  3. Ensure the passport JSON follows the required structure (all required fields present)
  4. Verify isCustomApplication: true is set in the passport JSON
  5. Check that applicationName and parentName are both "custom"
