Cards: Display Web Views with URLs
  • Jul 2, 2025 12:32 AM UTC
  • Oct 22, 2026 7:47 AM UTC
  • 1831 views
The Web View card allows customers to easily display websites (HTML), including your corporate website, a company blog page, or a news portal. Match the web page display with the screen resolution and size, display the web page at a custom resolution and size, or custom crop the page and display only a section of the web page.
For: IT Administrator — displaying a website with a Web View card
  • Change colors, text, icons, and images to match corporate branding standards.
  • Customize the layout to suit your corporate message and tone.
  • Fully responsive, works on mobile devices, tablets, desktops, and digital signage.
  • Category Type: Feed
  • Content Category Type: Productivity & Engagement
  • Tags: Dynamic, Web
Note:
To update an existing Web View Card to the latest template, see Cards: Update Web View Cards. On Appspace Platform 2603.4.0 or later, the update keeps the card configuration, the URL, channel publishing, and device assignments.
This article provides admins with instructions to create, configure, and customize the Web View card within the Library.
Prerequisite
Webpage Requirements
A Web View card displays a website on the device that plays the card. The page must load in the browser used by the embed option you select.
  • Native Webview (default). The card hands the URL to the device’s own browser. The page must run in that browser.
  • Iframe. The card embeds the page. A site that does not allow embedding, such as many social media sites, may not display.
  • XHR Proxy. Use this embed option when the page does not allow embedding.
  • Basic Authentication via XHR. This option is not supported on BrightSign devices running BrightSignOS 8.0 and above.
Important:
In the default Native Webview embed mode, the Web View card hands the URL to the device's own browser, so the website must be able to run in that browser. LG webOS Signage 4.0 and 4.1 displays (for example the 55UH5F) use Chromium 53, which LG does not update. webOS 6.0 uses Chromium 79 and can be upgraded to Chromium 94 through LG's LTS firmware program. webOS 6.1 and later ship with Chromium 94. Many current websites no longer render on Chromium 53 or 79 and show a blank screen. If a URL shows a blank screen on an older LG model, test the same URL in a desktop Chromium of the same version. If it fails there, use a newer display or an external media player.
Create and Configure Web View Card
Follow the instructions below to create and configure the Web View Card to display web content:
  2. Click Library from the ☰ Appspace menu, and click the + CREATE button.
    Alternative
  3. Select Feed from the templates panel, and click the Web View card.
    If you are unable to locate the card, you may use the search bar, filters, or side panel to narrow down the content you’re looking for.
  4. Enter the Title of the card as this acts as the filename for the card content. This is a mandatory field and defaults to “Web View” if none is added.
  5. In the Edit tab section:
    • Enter the website URL in the address field.
      Enter the URL of the page you want to display. If the page does not appear, check Webpage Requirements and select another embed option.
    • Select the desired Embed options:
      • Native Webview (default) – Displays web pages directly from the source on the device’s web browser.
        The background color will only be visible in editing mode and during device playback. In card preview and screenshot modes, the frameElement is inaccessible from the card, so the background will default to white.
        ​The page must run in the device browser. See Webpage Requirements.
      • XHR Proxy – Display web pages that do not allow embedding, by utilizing the XMLHttpRequest (XHR) proxy to bypass certain web browser security settings.
        • Proceed to configure the additional options.
      • Basic Authentication – Display web pages requiring basic authentication.
        • Proceed to enter the Username and Password used to authenticate the web page.
      • Basic Authentication via XHR – Display web pages requiring basic authentication, by utilizing the XMLHttpRequest (XHR) proxy method.
      • Iframe – Displays web pages by utilizing basic embedding methods, thus may not work on websites such as social media sites that do not allow embedding.
    • Configure the following additional options when the XHR Proxy or Iframe embedding options are selected:
      • Determine the Set website scaling:
        • Fit to screen – Screen resolution.
        • Custom size – Custom resolution.
          • Set the website resolution width and height (pixels)
        • Custom size with crop: – crop a particular section of the web page to be displayed.
          • Set the crop region (left, top, width, height)
      • Configure the More customization options:
        • Disable interactivity – Disables clicking or scrolling of the web page.
        • Display while loading – Displays web pages before it is fully loaded, with certain elements loaded after the web page is displayed.
      • Set the background color, or image for the card.
  6. In the Article tab section: Optional.
    • Include an Article or Caption to accompany the content when displayed in the Employee View and other social collaboration apps.
    • Add a Referral Link to link more information to the content.
  7. In the Schedule tab: Optional.
  8. In the Settings tab: Optional.
  9. Once done, click SAVE.
Configure Refresh on Network Recovery
Improvements to the Web View card ensure that in the event of a network interruption, the website displayed on the Web View card will be refreshed once the device has regained network connectivity, rather than display a blank white screen.
In order for this feature to work, the admin has to configure the card’s manifest.json file and ensure that the following property, “ReloadsOnReconnect” has been set to true: (false by default)
"ReloadsOnReconnect": true
