Cards: Display SharePoint Content
  • 898 views
The SharePoint card allows users with a Microsoft 365 account to access and display SharePoint posts, keeping organizational teams up-to-date on departmental matters, company updates, market news, and even world events. The card is built using the new Appspace integration with third-party systems that leverages standard technologies to create long-lived, authenticated, and secure connections.
An initial connection must be established between Appspace and a SharePoint Online service account, which is then stored in a virtual passport in Appspace and can be used until the service account revokes or cancels the integration. The passport will allow the card to establish a connection with the third-party system at runtime.
Read more about the integration architecture and how it all connects here in the Introduction to Appspace Integrations.
Please refer to our Introduction to Cards guide for an in-depth introduction to the types of cards that are ideal for your signage solutions. Visit our Appspace Card Gallery to find the perfect card template to deliver your message.
With the introduction of Content Categories in Appspace 8.0 ac.22, the SharePoint card template is assigned with the Productivity & Engagement content category.
This article provides instructions to create, configure, and customize the SharePoint card. You can refer to the latest updates with the SharePoint card in the SharePoint Card Release Notes
  • Account Owner  to configure account authentication in Integrations > Passport.
  • Appspace App 2.56.0 and later.
  • Appspace 8.2.0-ac.1 and later.
  • A Microsoft 365 SharePoint Online account for the organization domain.
  • When setting up a SharePoint passport for the first time, an administrator will see a window requesting permissions for SharePoint passport to access organizational data. If the window has a check box for consent on behalf of the organization, the administrator needs to enable it before clicking Accept. Failure to do so will result in SharePoint passports not working with SharePoint cards for users within the organization.
  • The Microsoft service account connected to the SharePoint Passport must be both a Site Owner and a Site Collection Administrator for the SharePoint site to ensure proper integration with Appspace.
  • Ensure your device is compatible. Refer to the Supported Appspace Cards article.
    Currently news articles, links, and video playback are not supported.
    Technical Limitations
    Please find the technical limitations for this card listed in the SharePoint card Release Notes.
Authenticate and Configure SharePoint Passport
Follow the instructions below to enter the Microsoft 365 SharePoint Online account information and configure the SharePoint passport to work with Appspace.
Appspace Account Owner or Publisher permissions are required. If you do not have the required permissions, you may still create the SharePoint passport by clicking the Set up a new passport link when configuring the SharePoint card.
  2. Click the ☰ Appspace menu, and then click Integrations.
  4. Select the SharePoint passport, and click CONNECT. Proceed to authenticate the passport, and grant permissions to access the Microsoft 365 account. You may be required to sign-in with your Microsoft 365 credentials if you are currently signed out.
    When configuring the SharePoint passport for the first time, an administrator will see a window requesting permissions for SharePoint passport to access organizational data. If the window has a check box for consent on behalf of the organization, the administrator needs to enable it before clicking Accept. Failure to do so will result in SharePoint passports not working with SharePoint cards for users within the organization.
  5. Follow the on-screen instructions to continue to configure the SharePoint passport.
  6. Once authenticated, in the Account Settings tab, you may perform the following actions:
    • Change the name of the passport, by entering a different name in the Name field.
    • View the Platform Privileges granted to the passport.
  7. In the Permissions tab, you may grant the following users or user groups permission to view or edit this passport configuration at any time:
  8. You may proceed to the Create and Configure SharePoint Card section below.
Follow the instructions below to display SharePoint posts:
  3. Select the Communication category, Productivity & Engagement under Content Category, or the OFFICE 365NEWS, and SHAREPOINT tags, and select SharePoint.
  4. Enter the Title of the content as this will also act as the filename for the content. The title defaults to ‘News’.
  5. In the Card display section on the left, select the SharePoint passport created earlier, or you may click the Set up a new passport to create one.
    If you are creating a new SharePoint passport, proceed to follow the on-screen instructions to authenticate the passport, and grant permissions to access the Microsoft 365 account. You may be required to sign-in with your Microsoft 365 credentials if you are currently signed out.
  6. Select the type of SharePoint posting from the drop-down menu:
    • Site Collections – Displays posts from a collection of SharePoint Sites managed by the Microsoft 365 account used to create the authentication passport earlier. Under the Pick SharePoint sites field,  you can select multiple SharePoint sites that the posts will originate from.
    • Single Article – Displays a SharePoint article that is managed by the Microsoft 365 account used to create the authentication passport earlier. Enter the URL of the article into the Search by article URL field.
  7. Click Select Account to confirm.
    Possible errors:
    • If the Microsoft 365 account does not have access to the SharePoint URL entered, the ‘URL is invalid’ message appears. Enter the correct URL.
  8. In the Edit tab:
    • If Site Collections was selected earlier, select the Layout that will be displayed:
      • If Single Article is selected, the card will display each single article in full screen
      • If Gallery is selected, the card will display an article in full screen and previews of the following articles
    • Enter the Title to be displayed as a sub-header in the card.
    • Enter the Number of Posts Displayed to set the total number of recent posts that will be retrieved from the account.
    • Click the Post Duration field to set the duration of each post displayed.
    • For Background Color or Media, you can click the color box to select the color of the background for the card, or upload an image.
    • If Single Article is selected for Layout, you can toggle the Show Author option to display the Author of each article.
  9. In the Article tab:
  10. In the Schedule tab:
  11. In the Settings tab:
    • The Name field will be auto-populated to match the Title of the content which will also act as the filename for the content. If left empty the Name and Title will default to ‘SharePoint’.
  12. Click SAVE.
  13. Proceed to the edit section below to add the card to a channel, preview the card, or view analytics once available.
Edit SharePoint Card
The instructions below show you how to edit a SharePoint card.
  3. Select and click the SharePoint card to edit, and select the desired tab to edit or view.
      • You may edit the content the same way as it was configured. For detailed instructions on how to do this, please refer to the Create and Configure section above.
    • In the Preview tab:
    • In the Channels tab:
    • In the Analytics tab:
  4. Click SAVE.
