This article provides the instructions to move advanced channels between or across different networks.
When moving advanced channels between networks, all devices assigned to the advanced channel will no longer be assigned to the advanced channel. The devices however will continue playing local content stored from the last update, and will not receive advanced channel updates from Appspace.
To move advanced channels between networks, please follow the instructions below:
Click Channels from the Appspace Menu navigation bar, and click the Channels tab.
Select the desired advanced channel.
Click the Settings tab, and click the Overview page.
Click the Network link, and select the desired network from the network tree in the Network window. Click OK once done.
The Network field now displays the network the advanced channel will be moved to. Click Save to make changes.
