Playout metrics enable digital media network operators to record the proof-of-play of content items within a media zone in an advanced channel (sign). Recordings can be set to always be captured or set to a scheduled time period. You can generate a report to display the proof-of-play between specific time periods.
Enabling Content Playout Recording
- Click Channels from the Appspace Menu navigation bar, and click the Channels tab.
- Select the desired advanced channel.
- Click the Edit tab, select the desired Media Zone widget.
- Check the Playout Metric in the PROPERTIES section.
- Click Apply, and exit the Widget Properties window once done.
Generating Content Playout Reports
- Click Admin > Reports from the Appspace Menu navigation bar, and click the Proof of Play Metrics tab.
- Select the Application & Content, Devices, and Date Range.
Content items will only be listed once the player is fully in-sync with the Appspace server.
- Click the Generate Report button, to generate and export the report in *.xls format. The report is automatically downloaded into your default download folder.
Your devices are required to have the channel running for at least 24 hours before the report data is available.
