Manage Links in Employee View
  • Sep 3, 2026 4:00 AM UTC
  • 36 views
Use My Links in Employee View to add, edit, and delete personal links to frequently used websites, applications, documents, and other resources.
The My Links widget is available from the user profile and displays only the links saved by the profile owner.
  • For: Employees — Personal Links Management.
  • The My Links widget must be configured and available on the user profile.
  • A valid http or https URL is required when adding a link.
Access My Links in Employee View
Follow the instructions below to access My Links:
  1. Log in to Appspace.
  2. If currently in Admin View, click the profile icon in the upper-right corner, and then click Go to Employee View.
  3. In Employee View, click the profile icon in the upper-right corner.
  4. Click Profile.
  5. Scroll to the My Links section.
The My Links widget displays the personal links saved to the profile.
Follow the instructions below to add a personal link:
  1. In the My Links section, click + Add link.
  2. In the Title field, enter a name for the link.
  3. In the URL field, enter the destination URL.
    The URL must use the http or https protocol.
  4. Click Save to add the link.
The link is displayed in the My Links section.
Note: Both the Title and URL fields are required.
Follow the instructions below to edit an existing personal link:
  1. In the My Links section, locate the link to update.
  2. Click the Edit icon for the link.
  3. Update the Title or URL as required.
  4. Click Save.
The updated information is displayed in the My Links section.
Follow the instructions below to delete a personal link:
  1. In the My Links section, locate the link to delete.
  2. Click the Delete icon for the link.
  3. Confirm the deletion, if prompted.
  4. Click Delete.
The link is removed from the My Links section.
Note: Personal links are private. Only the profile owner can view and manage links in the My Links widget.
