Need to discuss regarding location and access relation for some required changes.
Regards,
Mohit Kumar Singh
Hi ​@Mohit Kumar Singh, thanks for reaching out!
We definitely want to help you with the required changes regarding location and access. That being said, this topic can be quite broad, depending on your environment (e.g., are you referring to player location, user access, or content access?).
To ensure you get the most efficient and detailed information, might I suggest one of these two paths, or start with our helpful guide:
  1. Use our search bar to find existing articles and discussions. Searching for specific terms like "user roles," "content location," or "access management" often leads to immediate and comprehensive guides.
  2. If you need immediate, personalized support or guidance on a specific project, try engaging with Kirby, our chat agent, located in the lower right hand of your screen. Kirby can provide the necessary guidance to work through your detailed requirements.
Additionally, this article may get you started: Add and Manage Locations in Devices
Let us know if you can narrow down your question here, and we'll be happy to help you find the right information!
