Support Documentation
Android Debug Bridge Useful Commands
  • July 14, 2025
  • 123 views
Connecting to android device:
  1. Navigate to the location of ADB tools.
  2. Open a command prompt as the administrator where adb,exe is located.
  3. Type:
    Syntax
    adb connect <deviceIP>
    Example
    adb connect 192.168.3.101
  4. A success message will appear when the device is successfully connected.
adb root Restart the connection with root permission
adb devices list connected devices
adb shell am start -a android.settings.SETTINGS Open device android settings page
adb shell am force-stop com.android.settings Close android settings page
adb shell ps -ef List all  running  proceess
adb logcat -c   Clear all logs
adb logcat -b all -D -d  >>C:\temp\abdlogs.txt
Note: Path is configurable
Export device log to C:\temp\adblogs.txt
adb install <apk path>
Install  APK
Reference: https://www.automatetheplanet.com/adb-cheat-sheet/.
