Optimize Your Fullscreen Signage Channels: Best Practices for Building Playlists
Forum|alt.badge.img+4
A Full-Screen Signage Channel is most effective when its content, timing, and sequence match the display location and the audience’s expected dwell time. Use these recommendations as a starting point, then test and adjust them with real audience behavior.
  • More relevant content: Align the playlist with the audience and physical display context.
  • Better readability: Match message length and display duration to viewing distance and dwell time.
  • Balanced repetition: Use playout controls to repeat priority messages without overwhelming viewers.
  • Classifying display locations
  • Estimating content duration and playlist length
  • Testing readability
  • Building a balanced content mix
  • Using playout properties
  • Channel access: You need permission to create or edit the target Signage Channel.
  • Content inventory: Prepare approved cards and media in an accessible Library.
  • Audience information: Understand the audience, display location, typical dwell time, and communication goals.
Classify the Display Location
Points of Transit, Interval, and Interaction
Location type
Audience behavior
Example locations
Starting duration
Point of Transit
Viewers are moving through the space
Hallways, entrances, corridors
About 5–10 seconds for simple messages
Point of Interval
Viewers remain nearby for a short period
Breakrooms, cafeterias, lobbies, reception
About 20–30 seconds when content needs more detail
Point of Interaction
Viewers are actively using a screen or service
Kiosks, wayfinding, room booking, retail
Variable; match the task and interaction
Recommendation: These durations are planning ranges, not product requirements. Test the actual viewing environment.
Estimate Playlist Length
Use Exposure Math as a Planning Tool
A common planning goal is to expose a viewer to an important message several times during the expected dwell period. The following calculation is illustrative, not mandatory.
  • Potential exposures: Dwell time divided by the display duration of one item.
  • Estimated playlist size: Potential exposures divided by the desired number of exposures per message.
Example: A 15-minute dwell period contains 900 seconds. At 20 seconds per item, the viewer could see about 45 content slots. Targeting approximately four opportunities to see each message suggests a playlist of about 11 items.
Use judgment: Audience attention, arrival time, mixed content durations, dynamic feeds, and device behavior can all change the actual number of exposures.
Test Readability
Read the Message in Context
  • Preview at the actual resolution: Check the full channel or card at the destination display size.
  • View from the expected distance: Confirm that headlines and calls to action remain legible.
  • Use a repeated-read test: As a practical heuristic, try reading the message several times within its display duration. Shorten the copy or increase duration if it cannot be understood comfortably.
  • Prioritize the main point: Remove unnecessary details and keep the most important information visible at a glance.
Build a Balanced Playlist
Match Content to Audience
  • Public or reception areas: Company news, visitor welcome, social content, weather, health and wellness, and major announcements.
  • Internal office areas: HR and IT updates, project milestones, culture, recognition, performance, and local workplace information.
  • Breakrooms: Shift information, training, safety, scheduling, recognition, and local campaigns.
  • Production environments: Safety reinforcement, operational data, training reminders, and recognition.
Content mix: Treat content categories and percentages as adaptable editorial guidance. Build the mix around the organization’s goals and the audience’s needs.
Use Playout Properties
Control Timing and Frequency
  • Duration: Set a suitable display time for each content item.
  • Frequency restrictions: Use exact, maximum, loop-based, or airtime-based controls when available.
  • Schedule: Set start and end dates for time-sensitive content.
  • Dayparting: Target different shifts, days, or time windows.
Preview the final channel on a representative device and revise the sequence before broad deployment.
