Cards: Display Power BI Dashboards and Reports
  • August 20, 2026 at 10:22 AM
  • 2692 views
The Power BI Card allows organizations to display Microsoft Power BI dashboards and reports in Appspace.
While most devices are able to support displaying a live Power BI dashboard via our card, some devices for various reasons do not have the needed power to display live dashboards. To empower our customers, Appspace has also released a ‘screenshot service‘ that allows low-powered devices to display a screenshot of the Power BI dashboard. Whilst the dashboard display is not live on these devices, screenshots are updated every 15 minutes, and the screenshots are only available in landscape 16:9 (1920 x 1080 resolutions) and portrait 9:16 (1080 x 1920 resolutions) aspect ratios. If a card is assigned to a different aspect ratio zone, it will uniform fill.
The card is built using the new Appspace integration with third-party systems that leverages standard technologies to create long-lived, authenticated, and secure connections. An initial connection must be established between Appspace and a Microsoft Power BI service account, which is then stored in a virtual passport in Appspace, and can be used until the service account revokes or cancels the integration. The passport will allow the card to establish a connection with the third-party system at runtime.
Read more about the integration architecture and how it all connects here in the Introduction to Appspace Integrations.
This article provides instructions to create, configure, and edit the Appspace Power BI Card for displaying Power BI dashboards and reports.
  • Appspace App 2.29 and later.
  • Appspace 8.0 and later.
  • A Microsoft Power BI account.
    Important:
    For Power BI Passports configured with Delegated Permissions, ensure the following permission scopes are configured in Microsoft Entra ID:
    • General Microsoft-based passport scopes
      • offline_access
      • opened
      • profile
      • User.ReadBasic.All
    • MicrosoftPower BI specific scopes
      • https://analysis.windows.net/powerbi/api/Dashboard.Read.All
      • https://analysis.windows.net/powerbi/api/Workspace.Read.All
      • https://analysis.windows.net/powerbi/api/Dataset.Read.All
      • https://analysis.windows.net/powerbi/api/Report.Read.All
    Note:
    For detailed setup instructions and screenshots for Power BI Application Permissions, refer to the attached Power BI Application Permissions - Customer Checklist.
  • Account Owner or Publisher role to configure account authentication in Integrations > Passport.
  • Account Owner, Publisher, or Content Producer (Author) role to create or edit card in the Library.
  • Ensure your device is compatible. Refer to the Content Feeds table in the Supported Appspace Cards article for caveats.
    • BrightSign 1
    • Chrome OS 2
    • Cisco Collaboration Endpoints (CE) – Signage Mode
    • Crestron 3
    • iOS 5
    • Linux Ubuntu
    • MediaVue 4
    • Mersive 5
    • Universal Windows Platform (UWP) 5
    • Windows
      • 1  – BrightSign devices running firmware version 8.5 and above support displaying the live dashboard, while BrightSign devices running firmware version 8.4 and below support the screenshot service.
      • 2  – Unable to display Advanced Channels in Channel Browsing mode.
      • 3  – Channel Browsing mode is not supported on Crestron AirMedia and Mercury devices.
      • 4   – Only supported on MediaVue SureVue D2 devices. Unable to display Advanced Channels in Channel Browsing mode.
      • 5  – Unable to display playback for 24 hours.
  • Devices supported with screenshot service.
    • Android
    • BrightSign devices running firmware version 8.4 and below
    • LG WebOS
    • Samsung SSP 6.0 / Tizen 4
  • For Power BI Passports configured with Application Permissions, ensure the following requirements are met:
    • A Microsoft Entra Global Administrator, or equivalent, is available to grant tenant-wide admin consent.
    • A Power BI or Fabric Administrator is available to enable the required tenant developer setting.
    • A Power BI Workspace Administrator is available to configure workspace capacity and access.
    • The Power BI workspace uses a supported Power BI Premium, Power BI Embedded, or Microsoft Fabric capacity. A Power BI Pro license alone is not sufficient.
    • Use a custom Power BI workspace. My workspace is not supported.
    • Keep the dashboard or report and its semantic model in the same custom workspace.
  • The Power BI dashboards are not very responsive so they should be created with the display canvas in mind.
  • There are no styling options available for the dashboard on the card, as this is an embedded link. All styling should be done in the Power BI system.
Note:
Authenticate Power BI Account
Follow the instructions below to authenticate a Microsoft Power BI service account with Appspace:
Appspace Account Owner or Publisher permissions are required. If you do not have the required permissions, you may still create the Power BI passport by clicking the Set up a new passport link when configuring the Power BI card.
  2. Click the ☰ Appspace menu, and click Integrations.
  4. Select the Power BI passport, then select the permission type required for your Power BI use case:
    • Delegated Permissions
    • Application Permissions
      Important:
      The Power BI Passport permission type cannot be changed after the Passport is created. To switch between Application Permissions and Delegated Permissions, remove the existing Passport and create a new one with the required permission type.
  5. Click CONNECT, then complete the authentication for the selected permission type.
    • Delegated Permissions: Sign in with the Microsoft Power BI account that will be used by the passport.
    • Application Permissions: Sign in with a company Global Administrator account, then click Accept to grant tenant-wide admin consent.
      Note:
      Personal Microsoft accounts are not supported for Application Permissions. The account used to grant consent does not become the Passport identity; Appspace stores only the tenant ID.
  6. Once authenticated, in the Account Settings tab, you may perform the following actions:
    • Change the name of the passport, by entering a different name in the Name field.
  7. In the Permissions tab, you may grant the following users or user groups permissions to view or edit this passport configuration at any time:
  8. You may proceed to the Create and Configure a Power BI Card section below.
Follow the instructions below to display a Power BI dashboard or report:
  3. Select the Feed tag, and select Power BI.
  4. Enter the Title of the content as this will also act as the file name for the content. This is a mandatory field.
  5. In the Card section, select an existing Power BI passport, or click Set up a new Passport to create one. After the Passport is successfully configured, it becomes available for selection in the Power BI Card without restarting the card configuration workflow.
    • Dashboard – Displays a Power BI dashboard.
    • Report – Displays a Power BI report.
  6. Add the selected Power BI content using one of the following methods:
    • If you selected Dashboard and already have the Power BI Dashboard URL:
      • In the DASHBOARD field, enter the dashboard URL, and click Select Dashboard.
    • If you selected Dashboard and would like to search for the Power BI dashboard:
      • Select the Power BI workspace from the WORKSPACE dropdown menu, which is populated based on the passport account authenticated earlier.
      • Search and select the Power BI dashboard from the DASHBOARD field, and click Select Dashboard.
      • If you selected Report:
        • Select the Power BI workspace from the WORKSPACE dropdown menu.
        • Search for and select the Power BI report from the REPORT field, or enter the report URL.
        • Click Select Report.
          Note:
          If the report URL does not include a specific report page, the first page of the report is displayed by default.
    • If you selected Dashboard, configure the following fields in the right-side panel:
      • Mode Selection: Select the display mode for the card. The available options are:
        • Full Dashboard View: Embeds and displays the entire dashboard.
        • Report Mode: Displays reports individually.
          • Layout: This field appears when Report Mode is selected and allows you to choose a display layout for a single screen. The available options are:
          • Full Screen: Displays one report.
          • Grid of 2: Displays two reports.
          • Grid of 4: Displays four reports in a 2 × 2 grid.
  7. Once a dashboard or report is selected, you can preview the selected content. You may also edit or change the dashboard or report URL in the preview window. The URL must be valid or an error will be displayed.
  8. In the Article tab:
  9. In the Schedule tab:
  10. In the Settings tab:
  11. Click SAVE.
  12. Proceed to the edit section below to add the card to a channel, preview the card, or view analytics once available.
Edit a Power BI Card
When you edit a Power BI Card, the previously selected Passport, Workspace, and Dashboard or Report remain selected.
  3. Select and click the desired card to edit, and select one of the following tabs:
    • In the Article, and Settings tabs:
      • You may edit the content the same way as it was configured. For detailed instructions on how to do this, please refer to the Create and Configure section above.
    • In the Preview tab:
    • In the Channels tab:
    • In the Analytics tab:
  4. Once done, click SAVE.
Technical Limitations
  • The Power BI Free version currently restricts API calls and can hinder your ability to share dashboards and reports.
