Cards: Display Microsoft PowerPoint Presentations
  • July 20, 2026
  • August 14, 2026 at 9:53 AM
  • 632 views
The Microsoft PowerPoint Card displays presentations stored in Microsoft OneDrive or SharePoint through an authorized Microsoft 365 Drive Passport.
This article provides Communicators with instructions to create and manage Microsoft PowerPoint Cards, including selecting a presentation, configuring slide playback, and updating card settings.
Prerequisites​​​​​​​
  • A Microsoft 365 account with access to the required OneDrive or SharePoint presentation.
  • A Microsoft PowerPoint presentation stored in Microsoft OneDrive or SharePoint.
  • The presentation URL from OneDrive or SharePoint.
  • Account Owner permissions to configure passports from Integrations > Passports.
  • Author, Publisher, or Account Owner permissions to create and manage cards.
Authenticate and Configure a Microsoft 365 Drive Passport
Follow these instructions to connect a Microsoft 365 account and configure a Microsoft 365 Drive Passport.
  2. Click the ☰ Appspace menu, and then click Integrations.
  4. Select the Microsoft 365 Drive passport.
  5. In the Permission field, select the required permission type:
    • Delegated permissions – Uses the access permissions of the user authenticating the passport.
    • Application permissions – Uses tenant-wide admin consent and does not depend on a specific user login.
  6. In the Drive Resources Scope field, select the resources scope:
    • OneDrive
    • SharePoint
    • OneDrive and SharePoint
      Note:
      Select the resource scope that corresponds to the location of the PowerPoint presentations that will be used. A passport configured for OneDrive supports OneDrive presentation URLs, while a passport configured for SharePoint supports SharePoint presentation URLs. A passport configured for both supports either URL type.
  7. Once done, click CONNECT. Authenticate the passport and grant the required permissions to access the Microsoft 365 account. You may be required to sign in with your Microsoft 365 credentials if you are currently signed out.​​​​​​​
    Note:
    Microsoft Entra administrators can review the Appspace Drive Application and its granted Microsoft Graph permissions under Enterprise applications.
    The Appspace Drive Application appears in the Microsoft Entra enterprise applications list.
    The Permissions page displays the Microsoft Graph permissions granted to the Appspace Drive Application through administrator consent.
  8. Follow the on-screen instructions to continue configuring the Microsoft 365 Drive Passport.
  9. Once authenticated, in the Account Settings tab, configure and review the passport settings:
    • In the Name field, enter a descriptive name that identifies the user and the configured drive resource. Using a descriptive name is strongly recommended so users can identify the correct passport when creating a Microsoft PowerPoint Card.
      Recommended naming convention: [User Name] - [Drive Type]
      Examples:
      • John Smith - OneDrive
      • John Smith - SharePoint
      • John Smith - OneDrive and SharePoint
    • View the Platform Usages granted to the passport.
  10. In the Permissions tab, you may grant the following users or user groups permission to view or edit this passport configuration at any time:
    • Click +Add to browse users and user groups.
    • In the Browse Users and User Groups page, you may do the following:
      • Search or select the user(s) or user group(s) from the list, once done select, click Add.
      • Proceed to grant either Can Manage or Can View permissions.
  11. Proceed to the Create and Configure a Microsoft PowerPoint Card section.
Follow these instructions to create a card that displays a PowerPoint presentation.
  2. Use one of the following methods to start creating the card:
    • Click + Quick Action from the Appspace menu bar, and select Create Card.
    • Click Library from the ☰ Appspace menu, and open the library or folder where you want to create the card. Click + Create, and select Card.
    • Create and add the card directly to an existing channel. Refer to Add Content to Playlist Channels.
  3. Under the Feeds heading, locate and select the Microsoft PowerPoint card template.
    Important:
    If no Microsoft 365 Drive Passport is available, click Set Up a New Passport and follow the instructions in the ​​​​​​Authenticate and Configure a Microsoft 365 Drive Passport section.
  4. Select an authorized Microsoft 365 Drive Passport from the passport list.
  5. Paste a valid OneDrive or SharePoint presentation URL into the Presentation URL field.
    Note:
    Enter a presentation URL that matches the access configured for the selected Microsoft 365 Drive Passport. Use a OneDrive URL for a passport configured for OneDrive and a SharePoint URL for a passport configured for SharePoint. A passport configured for both supports either URL type.
  6. Confirm the presentation selection.
  7. Review the presentation in Preview mode.
  8. Update the card name, if required.​​​​​​​
  9. In the Edit tab:
    • Click Slide Duration to configure the slide playback interval.
      Note:
      The default interval between slides is eight seconds. When Manual is selected, user input, such as a mouse action, is required to navigate between slides, use the laser pointer, or jump to a specific slide.
    • Click the back arrow on the left side of the slide preview to return to the passport and presentation selection page.
  10. In the Article tab:
  11. In the Schedule tab:
  12. In the Settings tab:
    • The Name field will be auto-populated to match the Title of the content which will also act as the filename for the content. If left empty the Name and Title will default to ‘Microsoft PowerPoint’.
  13. Click SAVE.
  14. Proceed to the edit section below to add the card to a channel, preview the card, or view analytics once available.
Edit a Microsoft PowerPoint Card
The instructions below show you how to edit a Microsoft PowerPoint card.
  3. Select the Microsoft PowerPoint Card to edit, and select the desired tab to edit or view.
      • You may edit the content the same way as it was configured. For detailed instructions on how to do this, please refer to the Create and Configure section above.
    • In the Preview tab:
    • In the Channels tab:
    • In the Analytics tab:
  4. Click SAVE.
Technical Limitations
  • PowerPoint file updates: Appspace polls OneDrive and SharePoint for changes at five-minute intervals. Updates saved to the source PowerPoint file are reflected on the Microsoft PowerPoint Card within five minutes.
  • Static slide rendering: Appspace renders PowerPoint slides as static image snapshots. Therefore:
    • Embedded video and audio content is not rendered or played on the Microsoft PowerPoint Card.
    • PowerPoint animations and slide transition effects are not supported.
