Cards: AI Generate Card
  • September 11, 2025
  • July 8, 2026 at 5:07 AM
  • 765 views
The AI Generate Card, part of the Appspace Cards framework and powered by Appspace Intelligence, introduces a streamlined approach to visual content creation by transforming text prompts into professionally styled cards within seconds.
With support for multiple layout options, visual styles, themes, and design tools, the AI Generate Card is well-suited for corporate announcements, digital signage, internal campaigns, and workplace updates. Generated cards can be further customized by editing text, images, and layers directly in the editor.
This article provides instructions for creating, configuring, and editing AI Generate Cards in Appspace.
Prerequisite
Create and Configure Generate Card
The instructions below allow you to create Generate card.
    • Click +Quick Action from the Appspace menu bar on the top right, and select Create Card
  3. There are two ways to use AI Generate Card:
    • From the Library, click the Create dropdown menu and select Generate Card.
    • From the Library, select Create and then choose All Templates. Under “Kickstart your cards with AI,” select Card.
  5. Click the Language icon > + Select default language.
  6. In the Select Default Language window, choose your desired language from the drop-down list. A total of 33 languages are available:
    • Arabic
    • Bulgarian
    • Catalan
    • Czech
    • Danish
    • German
    • Greek
    • English (Default)
    • Spanish
    • Spanish (Latin America)
    • Finnish
    • Canadian French
    • Hindi
    • Hungarian
    • Italian
    • Japanese
    • Korean
    • Lithuanian
    • Latvian
    • Norwegian
    • Dutch
    • Polish
    • Portuguese
    • Portuguese (Brazil)
    • Romanian
    • Slovak
    • Serbian
    • Swedish
    • Thai
    • Turkish
    • Simplified Chinese
    • Traditional Chinese
      Notes:
      When multiple languages are selected for a location, the card displays translations in rotation. For example, if English, Spanish, and French are selected, loop 1 shows English, loop 2 shows Spanish, loop 3 shows French, and loop 4 returns to English.
  1. Once done click Save.
  2. In the Edit tab:
    • Describe the message and template you want to create.
    • Click the Style option to choose a design style:
      • Realistic
      • Abstract
      • Minimalistic
      • Macro
      • Vector
      • Flat
      • Pop Art
      • Fantasy
      • Pattern
      • Surrealism
      • Line Art
      • Watercolor
    • Click the Layout option to choose a design style:
      • Text Only
      • Media Background
      • Split Media
      • Media Sidebar
      • Media Top
      • Media Bottom
      • Spotlight
      • Gallery Grid
    • Click the Theme option to choose a design style:
      • Light
      • Dark
      • Branded
    • Click the + upload image button to upload desires image.
    • Once done click Generate.
    • Once the card is generated, the design tools are displayed in the editor. You can use these tools to add or update text, images, and layers in the card design.
    • In the design tools, you may do the following:
      • Text - Add a text box, title, headline, subheadline, body text, overline, or overline pill.
      • Images - Upload an image, select an image from the library, or generate AI media.
      • Layers - View and manage the arrangement of design elements on the card, such as text, images, and stacked or unstacked objects.
        Note: You can update text and images using the design tools or directly from the editor canvas. Hover over the text or image you want to change, then select the available editing option.
  3. In the Article tab:
    • Include an Article or Caption to accompany the content item when it is displayed on mobile apps, tablets, and other social collaboration platforms. You can also use Ask AI to automatically generate this text.
  4. In the Schedule tab:
  5. In the Settings tab:
    • Select Download to download the generated card as a ZIP file.
    • Select Delete to delete the card.
  6. Once done, click SAVE.
  7. In order to display the Generate Card, proceed to add the card to a playlist channel, and publish the playlist channel.
Edit Generate Card
The instructions below show you how to edit an Generate card.
  3. Select and click the Generate card to edit, and select the desired tab to edit or view.
      • You may edit the content the same way as it was configured. For detailed instructions on how to do this, please refer to the Create and Configure Generate Card section above.
    • In the Preview tab:
    • In the Channels tab:
    • In the Analytics tab:
  4. Once done, click SAVE.
