Can a Power BI Card Cycle Through Different Filters?
  • Sep 4, 2026 4:00 PM UTC
  • 30 views
Dave Becker
Forum|alt.badge.img+3
How Can I Display Multiple Filtered Views?
If you want your display to rotate through different filtered views of the same Power BI report, create an individual Power BI card for each filtered view.
Then, add those cards to a playlist so Appspace can rotate through each view on the display.
  • Filter 1 — Create a Power BI card with the first filtered view.
  • Filter 2 — Create another card with the second filtered view.
  • Additional filters — Repeat for any other views you want to display.
  • Playlist — Add the cards to a playlist in the order you want them displayed.
This allows you to create a rotating experience using Appspace, even though the Power BI card itself does not cycle between different filter configurations.
